  1. please can u help a cat?
    however
    consider, as example, this mkv file:
    https://www.swisstransfer.com/d/35a45ca1-5123-460b-8d40-d295429aafe0
    In Avidemux --> File -->Open --> c:\example.mkv
    and then
    from menu "File" --> "Project Script" --> "Save as Project" --> c:\example.py
    This is the example.py opened with the notepad:
    #PY  <- Needed to identify #
    #--automatically built--
    adm = Avidemux()
    if not adm.loadVideo("C:/example.mkv"):
        raise("Cannot load C:/example.mkv")
    adm.clearSegments()
    adm.addSegment(0, 120000, 4720000)
    adm.markerA = 0
    adm.markerB = 4720000
    adm.setHDRConfig(1, 1, 1, 1, 0)
    adm.videoCodec("Copy")
    adm.audioClearTracks()
    adm.setSourceTrackLanguage(0,"und")
    adm.setSourceTrackLanguage(1,"und")
    if adm.audioTotalTracksCount() <= 0:
        raise("Cannot add audio track 0, total tracks: " + str(adm.audioTotalTracksCount()))
    adm.audioAddTrack(0)
    adm.audioCodec(0, "copy")
    adm.audioSetDrc2(0, 0, 1, 0.001, 0.2, 1, 2, -12)
    adm.audioSetEq(0, 0, 0, 0, 0, 880, 5000)
    adm.audioSetChannelGains(0, 0, 0, 0, 0, 0, 0, 0, 0, 0)
    adm.audioSetChannelDelays(0, 0, 0, 0, 0, 0, 0, 0, 0, 0)
    adm.audioSetChannelRemap(0, 0, 0, 1, 2, 3, 4, 5, 6, 7, 8)
    adm.audioSetShift(0, 0, 0)
    if adm.audioTotalTracksCount() <= 1:
        raise("Cannot add audio track 1, total tracks: " + str(adm.audioTotalTracksCount()))
    adm.audioAddTrack(1)
    adm.audioCodec(1, "copy")
    adm.audioSetDrc2(1, 0, 1, 0.001, 0.2, 1, 2, -12)
    adm.audioSetEq(1, 0, 0, 0, 0, 880, 5000)
    adm.audioSetChannelGains(1, 0, 0, 0, 0, 0, 0, 0, 0, 0)
    adm.audioSetChannelDelays(1, 0, 0, 0, 0, 0, 0, 0, 0, 0)
    adm.audioSetChannelRemap(1, 0, 0, 1, 2, 3, 4, 5, 6, 7, 8)
    adm.audioSetShift(1, 0, 0)
    adm.setContainer("MKV", "forceAspectRatio=False", "displayWidth=1280", "displayAspectRatio=2", "addColourInfo=False", "colMatrixCoeff=2", "colRange=0", "colTransfer=2", "colPrimaries=2")
    but now please consider only this line:
    so this value (4720000) is the "duration" of entire clip from start to end in Avidemux.
    I wonder: is there a way to get this value with a batch procedure, but without having - every time for a single file - manually open Avidemux and --> "Open file" -->"Save project" --> open in notepad and get the value?
    I mean: is there a way, with a batch, to automatic get the value (in this case is 4720000)
    so the final result is:
    OR
    eventually: is there a way to execute in commandline something like:
    avidemux.exe --load c:\example.mkv
    [and save the project in a .py file] ?
    My target is simple to get:
    and not other.
    thanks
  2. Just use ffprobe. It will get the duration in seconds:
    ffprobe.exe -v quiet -show_entries stream=duration -of default=noprint_wrappers=1:nokey=1 -select_streams v:0 %1 >duration.txt
    set /p duration=<duration.txt
    ffmpeg... b:v=DESIRED_STREAM_SIZE_IN_BYTES*8/%duration%...
    Of course, you should already know how to do this as you've done similar things before.
  3. Originally Posted by jagabo View Post
    mmm thanks but if I do, on c:\example.mkv
    rem
    if exist c:\duration.txt del c:\duration.txt
    rem
    ffprobe.exe -show_entries stream=duration -of default=noprint_wrappers=1:nokey=1 -select_streams v:0 "c:\example.mkv">c:\duration.txt
    rem
    duration.txt is:
    N/A
    how can it be?
    thanks
  4. It appears you video stream has no time codes. Try using "format=duration" instead of "stream=duration".
  5. Code:
    if exist "%cd%\duration3.txt" del "%cd%\duration3.txt"
    ffprobe64bit2022.exe -v error -select_streams v:0 -show_entries format=duration -print_format default=nokey=1:noprint_wrappers=1 "c:\Volumes\tmp_whatsapp.avs\tmp_whatsapp.avi">"%cd%\duration3.txt"
    fart.exe -q "%cd%\duration3.txt" . --remove
    set /p AviDemuxDur=<duration3.txt
    ah wow
    but please keep in mind the brain-cat-limited
    so that using
    so for example i get
    from
    is a vulgarity but however seems to works
