Hi
Based on a previous post by jagabo, I have used this batch file to check for errors in an individual file where I drag and drop a mp4 file onto the batch file:
c:\ffmpeg\bin\ffmpeg.exe -v error -i "%~dpnx1" -f null - >"%~dpnx1.error.txt" 2>&1
Sample output:
[h264 @ 000002175c2ed3a0] top block unavailable for requested intra4x4 mode -1 at 13 0
[h264 @ 000002175c2ed3a0] error while decoding MB 13 0, bytestream 7
How would I make a similar batch file for a folder of files?
Also, I tried using mp4box to get info on a mp4 file:
c:\gpac\mp4box.EXE -v -info "d:\This is My File.mp4"
pause
which does provide lots of information
Again how would I make a batch file to get info on a folder of mp4 files?
TIA
Results 1 to 21 of 21
Try this. Run from within the folder with all the .mp4 files
Code:for %f in (*.mp4) do ffmpeg.exe -v error -i "%~f1f" -f null - > "%~nff.error.txt" 2>&1
Hi jack_666, can that me modified to iterate through the current folder and sub folders ?
@jack_666
Thanks for your input - it kind of works
I had to add the full path of ffmpeg and I had to change the % to %% and I had to remove the lf from "%~flf"
when I tried
for %%f in (*.mp4) do "c:\ffmpeg\bin\ffmpeg.exe" -v error -i "%%~f" -f null - > "%%~nff.error.txt" 2>&1
pause
I got this text output:
MyFile.mp41f: No such file or directory
when I removed the lf and tried this
pause
the command window did not separate the text files with a line break
and the text output was:
^C
but for some strange reason when I used this:
for %%f in (*.mp4) do "c:\ffmpeg\bin\ffmpeg.exe" -v error -i "%%~f" lf -f null - > "%%~nff.error.txt" 2>&1
pause
text output for mp4 with no error
[NULL @ 0000029f4697d200] Unable to find a suitable output format for 'lf'
lf: Invalid argument
text output for mp4 with error
[mov,mp4,m4a,3gp,3g2,mj2 @ 000002a21987a4a0] moov atom not found
MyFile1.mp4: Invalid data found when processing input
and when I used 1 instead of lf
for %%f in (*.mp4) do "c:\ffmpeg\bin\ffmpeg.exe" -v error -i "%%~f" i -f null - > "%%~nff.error.txt" 2>&1
pause
text output for mp4 file with no error
[NULL @ 000001f60f7cd200] Unable to find a suitable output format for '1'
1: Invalid argument
[mov,mp4,m4a,3gp,3g2,mj2 @ 000001e05781a4a0] moov atom not found
so, for some reason when an "invalid argument", i.e. the use of lf or 1 is used the command prompt output show lines breaks when displaying the filenames and processes each outputted text file
Obviously a better way to do this is to find the correct code to add line breaks -
Please try
Code:for /R %%f in (*.mp4) do ffmpeg.exe -v error -i "%%~ff" -f null - > "%%~nff.error.txt" 2>&1 echo. echo press any key to exit ... & pause>nul & exit
The previous code was for running from the terminal. It looks like you prefer to run from a script.
(for cmd scripts you need to change % to %%)
Therefore, copy the above code and paste in the folder with all your other mp4 files. Save as "whatever.cmd"
Double click to run.
@JN-
I have added the /R in the above script so as enable subfolder searches. -
Thanks Jack, ive been struggling for a while now, found the /R option, but cannot output the filename. Will look at that now and get back.
for /R %%G in (*.mp4, *.mov) do echo --------------------------------------------------------------------------->>Error-List.txt& ffmpeg -v error -i "%%G" -f null - >>Error-List.txt 2>&1
Typical output ... two files, 2 lines per file.
--------------------------------------------------------------------------- Section 2 START
[null @ 000001bbb9e05d00] Application provided invalid, non monotonically increasing dts to muxer in stream 0: 671 >= 667
[null @ 000001bbb9e05d00] Application provided invalid, non monotonically increasing dts to muxer in stream 0: 671 >= 671
[mov,mp4,m4a,3gp,3g2,mj2 @ 00000272ed8b34c0] moov atom not found
PRETEND-Video-file-4.mp4: Invalid data found when processing input
--------------------------------------------------------------------------- Section 2 END
As you can see the top 2 lines is 1 file with problems, but I couldn't manage to output the filename.
The third and fourth lines is also a single file, but it does give the filename.
I will check out what you posted now and get back, thanks.Last edited by JN-; 8th Feb 2023 at 21:32.
Well done Jack. I hope I am not intruding on the OP here, what I was hoping to achieve is to output to a "Single" text file with the file names of the problem files, with the errors.
Your method works but involves a separate output file for all problem files.
This nearly works but I cannot figure out how to output say the filename with the errors ...
I don't know how to insert that line into the "box"
Some errors from the above syntax do output the filename as in my earlier post "6" but some file errors don't. What I am after may not be possible.
My interest in this thread is that a few months back I accidently discovered that quite a few of my videos were corrupt, no idea how it happened. A buddy of mine noticed that the "Explorer" files icon on the corrupt files was different, so I was able to track down all of them and replace with a backup video.
Using something like this, which I never knew existed would be a great way to say once or twice a year check it out. It would take a while to run be still extremely useful.Last edited by JN-; 8th Feb 2023 at 21:31.
@wiseant .... you have not been forgotten
@ JN- please try this
Code:type NUL > Error-List.txt for /R %%G in (*.mp4, *.mov) do echo ------------------ Testing : "%%~fG" -------------------------------->> Error-List.txt & ffmpeg -v error -i "%%~fG" -f null - >> Error-List.txt 2>&1 echo. echo press any key to exit ... & pause>nul & exit
Fantastic, thank you. I was gone to bed (4AM)when I saw this post and now back at laptop, will really pay for this tomorrow, today.
This is great. Will study it, but looks really great. Brilliant. -
The FOR command is always tricky, for me anyway. I tried for a long time and couldn't get it, so I think I get it now, the way you got it working within the FOR command is using the f like Parameter Extensions,. "%%~fG"
Thanks to your code I was able to get what I wanted, very useful, thanks Jack and thanks wiseant for bringing this issue up, I intend to make use of it.
FWIW This is what I finished up with. I didn't include the "duration" code as it would be too long but have included the reference.
@echo off
cls
color 0A
SETLOCAL EnableDelayedExpansion
mode CON:cols=150 lines=20
TITLE Get video files Errors. Start Date and Time [%DATE%] ... [%TIME%].
REM Get duration var reference ...
REM by Yinon, 7th-Oct-2014
REM http://stackoverflow.com/questions/9922498/calculate-time-difference-in-windows-batch-file
CALLURATION_PART1
REM Parameter Extensions, some used below: Example C:\utils\MyFile.txt
REM %~f1 = Expand %1 to a Fully qualified path name - C:\utils\MyFile.txt
REM %~d1 = Expand %1 to a drive letter only - C:
REM %~p1 = Expand %1 to a PATH - \utils\ this includes a trailing \ which will be interpreted as an escape char by some commands.
REM %~n1 = Expand %1 to a file Name only - MyFile
REM %~x1 = Expand %1 to a file eXtension only - .txt
REM Use next line to reset/delete output file.
REM type NUL > Error-List.log
REM If exist Error-List.log del Error-List.log
echo.>>Error-List.log
echo ------------------------------------------------------------------------------------------ [%DATE%] ... [%TIME%] --------------------------------------------------------------------------- START>>Error-List.log
REM the extension is not case sensitive i.e. .mts can catch .MTS also. "%%~fG" has to be enclosed in "" to handle filenames with spaces in them.
SET /A _FILES_FOUND=0
for /R %%G in (*.mp4, *.mov, *.mts, *.avi) do (
echo ------------------------------------------------------------------------------------------------------------------------- [%%~nxG] ... [%%~pG]>>Error-List.log
ffmpeg -v error -i "%%~fG" -f null - >> Error-List.log 2>&1
SET /A _FILES_FOUND+=1
TITLE Get video files Errors. Start Date and Time [%DATE%] ... [%TIME%]. Files found = [ !_FILES_FOUND! ].
CALLURATION_PART3
echo -------------------------------------------->>Error-List.log
echo Duration = [%_TOTAL_TIME_TAKEN_%]. Files found = [%_FILES_FOUND%].
echo Duration = [%_TOTAL_TIME_TAKEN_%]. Files found = [%_FILES_FOUND%].>>Error-List.log
echo ------------------------------------------------------------------------------------------ [%DATE%] ... [%TIME%] --------------------------------------------------------------------------- END>>Error-List.log
echo & REM To notify processing has ended.
echo [30m [40m & REM Black on Black, to hide the TIMEOUT countdown display.
TIMEOUT 2 & REM If I don't use a short delay, the bell won't sound.
cls
color
SET _FILES_FOUND=
EXITLast edited by JN-; 9th Feb 2023 at 19:55.
@jack_666
But if I add an invalid argument i.e. 1 as I did before, it gets the same result as before:
1: Invalid argument
it does process sub-directories -
@JN- ... You are most welcome. The pleasure was mine. Also, sorry I kept you up so late and thanks you sharing your script.
@wiseant
Usage instructions:
1) Within your folder containing all your mp4 files, right click ==> New ==>
2) name the txt document whatever.txt
3) double click whatever.txt and a blank file opens in Notepad
4) Copy the required code that I posted and paste into the blank Notepad document. (Ctrl C, Ctrl V)
5) Click File ==>Save As ==> whatever.cmd (note the extension change)
6) double click whatever.cmd
7) the code will now run.
It may take a long time to complete a mp4 file especially if it is large. You have to wait until "press any key to exit" is displayed
Suggest that you create a new folder with, say, three mp4 files (the smallest ones). Execute the process.
Another suggestion is to use the code that I provided to JN-. This is possible a better solution to your challenge.
Hope this helps.
Another suggestion is for you to upload your file with error so that someone can have a look.
My unerstanding is that a blank output means that ffmpeg did not find an error -
@jack_666 "sorry I kept you up so late" Worth it ! I'm currently running it against 2 separate folders of 194 and 234 video clips, two separate instances, it'll take a while.
Useful to have.
"My unerstanding is that a blank output means that ffmpeg did not find an error" That seems to be the case. -
@jack_666
I am running a batch file
I copied the code - pasted into notepad++ - saved as .bat file -
You can speed up checking (although detecting fewer errors) by processing only an audio track, no video:
Code:-map 0:a:0
@wiseant
you are telling me that you ran the code
echo.
in a folder with several mp4 files and it only processes the first mp4 and then you see
This does not make any sense. -
@jack_666
Success
My mistake was a lack of patience - I was using my slower computer and the first mp4 file was rather large - I didn't see any results so I ended the batch
When I used my faster computer [ i5-12400 CPU] and noticed that the cpu usage was 99% - I let it do its thing:
125 files with a total size of 221.70 GB with a total playing time of 94 hours took 142 min = 1.56 GB per minute
8 mp4 files have significant errors
Thanks jack_666 -
you are most welcome.
The person that should get the credit is jagabo, after all it was his code that was usedLast edited by jack_666; 10th Feb 2023 at 23:42.
Batch file to extract/convert all tx3g files in an .mp4 file
By olpdog in forum SubtitleReplies: 1Last Post: 23rd Aug 2020, 18:40 -
Coding errors when rendering a FHD file into *.mp4 by Corel Video Studio
By Bert37 in forum Video ConversionReplies: 2Last Post: 29th Dec 2019, 10:27 -
Create batch file for ffmpeg to increment the file output
By Bassquake in forum Video ConversionReplies: 2Last Post: 25th Nov 2019, 05:03 -
MP4 File Re-Sync Batch Conversion (Avidemux?)
By lplp in forum Video ConversionReplies: 1Last Post: 20th Sep 2019, 23:47 -
How to set ffmpeg File Path on Batch File
By Daringbaaz in forum Newbie / General discussionsReplies: 2Last Post: 28th Jul 2019, 05:55
