I have Spiderman in one full 700m AVI file and I want to convert it to a VCD to play through my DVD player. I'm a complete newbie to this and am really struggling. Can somebody please help me? If you could tell me in steps what I need to do and how to do it I would be extremely grateful.
Results 1 to 15 of 15
I use two programs when I do this conversion. First Virtualdub. I go to Audio click Full Processing mode and the set the hertz and save the audio of the movie as a *.wav file under da file menu.
After I have da audio/Sound part of the movie takeing care of useing VirturalDub. I launch the program TMPGEnc. Useing this program. I click da video input part to where my *.avi movie is located on my computer. I then switch da audio input to da file Virtualdub made me eailer. This way I have audio and sound working. Then I just load where i want the output movie to go and click convert. This will convert the movie into a *.mpeg....
Useing the burning program Nero... I convert the mpeg into a VCD movie. This usully works for me. Hope this is any help. If not. I recommand useing the articals the site provides.
If your movie is to big after doing this to be able to put on cd....
Just send me a message.
Peace. -
what if I needed to split? will Vdub spil precisely what tmpgenc splits, this way the audio matches?
Please advise. -
PLAYINGDIRTY
If you movie is in avi format use this guide
http://www.vcdhelp.com/divxtovcd.htm[url]
It's the guide that IMP8783 is talking about except he using nero instead of vcd easy. That is exactly how I do it, and have no problems.It explains how to split the files in the guideWe were all NEWBIES once and the only stupid question is the one that's not asked? -
why not just skip the virtual dup stuff & drop it straight into tmpeg??? it will be faster all U need is the divx codecs loaded & then follow the tmpeg guides for creating a vcd. This should work without any hitches.
Kev! -
i tried just using tmpgenc, no sound when i play back using windows media on my comp. i do have divx codecs 3.11 4 and 5, also nimo codecs pack
still no sound. but when i play my avi there is sound..
The link is forbidden for me....unless its because im at work..hmmm?
ps. hows the quality on the spiderman movie? just another video camera in the theatre?
thanks! -
I srewed up on that link I made the whole post an url my fault try it again it will work now
If you use this guide you should have no problemsWe were all NEWBIES once and the only stupid question is the one that's not asked? -
I'm not sure about what loumarx wrote, but I think it is a guide to convert a dvd to a svcd. I think you should stick to the guide I told you,because your movie is in avi format.
You want to follow the DivX to VCD conversion guide under CONVERSION to the left.
You'd want to strip out the wav due to the VBR in the audio. Yes, you could drop it straight into TMPG if you'd like Synch issues. There is a way to set the timing skew, in TMPG so you can do that, but I am not gonna get into explaining that.
In short, follow this, http://www.vcdhelp.com/divxtovcd.htm, as well as use your SOURCE RANGE filters to split the clips up front, and you'll be cool.~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
SEE SPIDERMAN
himself agrees :lol:We were all NEWBIES once and the only stupid question is the one that's not asked? -
lol, this is not even my thread and i have the most questions! thanks for all your help...
hmm last but not least..where are you guys finding divx, avi, bin/cue to download?? "screeners - dvd format" movies? i tried edonkey..too damn slow!! -
DVD2SVCD is a software that now supports the following conversions: DVD/AVI/PVA to MPEG 1/MPEG 2
www.doom9.org
Why does my conversion not play Full Screen?
By dexterdoo in forum Video ConversionReplies: 6Last Post: 27th Jan 2012, 07:37 -
Full Screen Ipod Nano 5th gen conversion
By nerys in forum Video ConversionReplies: 12Last Post: 16th Jan 2010, 14:31 -
Full conversion MKV subs to avi subs & fonts intact.
By ashidosai in forum Video ConversionReplies: 28Last Post: 18th Oct 2008, 17:36 -
PAL to NTSC DVD [Full Disc] Conversion (hybrid method, very easy)
By LadyLiete in forum User guidesReplies: 28Last Post: 5th Nov 2007, 21:35 -
Better methods of AVI to VCD conversion?
By HerronScott in forum Video ConversionReplies: 3Last Post: 25th Oct 2007, 00:51
