  1. Hi! I have a DVD footage from different sources and in one of them colors are slightly changed. Can you help me please to choose the right filters and settings to improve it? I have an examples:
ID:	69072Click image for larger version
    Original color                                             Needs a correction
ID:	69074Click image for larger version
ID:	69076Click image for larger version
    Original is more colourful as you can see Thank you in advance for any help!
  2. I don't know about PP but this adjustment in AviSynth gets close-ish:
    Tweak(sat=1.20, cont=0.88, bright=15)
    [Attachment 69083 - Click to enlarge]
    You can probably translate the saturation, contrast, and brightness settings to similar filters in PP.
    To get closer you need to work in YIQ space and increase the I and Q saturation separately.
  3. Wow, thank you very much, jagabo!!! This is exactly what I need, it's even much more suitable for me! Can I also ask how to set Gaussian blur in AviSynth?
  4. Originally Posted by artemiy1701 View Post
    Try the Variable Blur package: http://avisynth.nl/index.php/VariableBlur#Filters
    Here's a slightly more accurate color adjustment with AviSynth:
    Tweak(hue=-45).ColorYUV(cont_u=55, cont_v=90).Tweak(hue=45) # color adjustment
    Tweak(cont=0.88, bright=15) # levels adjustment
