  1. Anonymous
    Guest
  2. You can do it in avisynth - using ConditionalReader to read a .txt file with the wanted frames, and ConditionalFilter to select only those to write out
    Framenumbering starts at "zero"
    If your video is YUV, you probably want to use Rec709 for HD, Rec601 for SD to write images. In the example below, I used 709, progressive, no alpha channel. There are other considerations if it's interlaced, or other colorspaces. Provide more info if it's none of these
    The source filter you would use, depends on the type of video. A general one would be FFVideoSource which could load most types
    eg.
    FFVideoSource("video.ext")
    orig=last
    write=orig.ConverToRGB24(matrix="rec709").ImageWriter("file_%06d.bmp")
    ConditionalFilter(orig, write, orig, "value", "=", "1")
    ConditionalReader("framenumbers.txt", "value")
    For framenumbers.txt, create another column in your existing excel sheet , where each value has 1 beside it. Essentially "1" turns "on" the frame, "0" turns off. You only need to list included frames. Copy/paste into a text file. Rename it "framenumbers.txt"
    So if you had 323, 6543, 7000 (just for this simple example)
    Type int
    Default 0
    323 1
    6543 1
    7000 1
    You can use drop & drag the .avs script in vdub and use file=>run file analysis pass. And it will write the chosen frames, with the correct framenumber written into the filename. You can change the filename syntax in the ImageWriter argument (maybe you want to call it something more descriptive than "file" )
    Right now it would write
