Hi guys, I am a newbie and I learn a lot from this forum.
I tried to download video from vrt max. Everything went great but I failed in the decrypt phase. I guess the problem is I used wrong kid:key pair. I just simply copied the default_kid in the mpd file. Which didn't match the format in successful code.
I am using macos 13.0 and I use N_m3u8DL-RE and mp4 decrypter.
I follow this thread https://forum.videohelp.com/threads/407962-download-from-VRT-MAX
And tutorial https://forum.videohelp.com/threads/404994-Decryption-and-the-Temple-of-Doom
but I know it is currently out of my ability to get the kid:key pair. So I turn to you guys for help.
I hope I can get kid:key pairs for all 6 episodes...ORZ. If that bothers you, ep01 and ep03 is enough! Thanks in advance!
And one more questions, is the kid:key value pair unique for each video? Or I can use the website's key for all this season?
video link: https://www.vrt.be/vrtnu/a-z/kampioenenjaar/1/kampioenenjaar-s1a1/
My account info for vrt max:
username: jonaxyy@outlook.com
pw: 24rosasABC
This is output from my last try. Seems I failed in decrypt phase.
N_m3u8DL-RE_Beta_osx-arm64 % ./N_m3u8DL-RE -M format=mp4 --key "2B72B3A7-9B0B-D9B6-A19F-C34DDE309A76" "https://remix.vrtcdn.be/content/vod/pl-bd8576e3-2a2d-4cdc-a6d1-be99f79949cb/pl-bd8576e3-2a2d-4cdc-a6d1-be99f79949cb_drm_0ee71428-7e14-4170-b449-902556ddacb7.ism/.mpd" --save-name "ep_02" -sv best -ss all
13:19:52.918 INFO : N_m3u8DL-RE (Beta version) 20230111
13:19:52.969 INFO : Loading URL: https://remix.vrtcdn.be/content/vod/pl-bd8576e3-2a2d-4cdc-a6d1-be99f79949cb/pl-bd8576e...dacb7.ism/.mpd
13:19:53.272 INFO : Content Matched: Dynamic Adaptive Streaming over HTTP
13:19:53.273 INFO : Parsing streams...
13:19:53.337 INFO : Extracted, there are 9 streams, with 6 basic streams, 2 audio streams, 1 subtitle streams
13:19:53.341 INFO : Vid *CENC 1920x1080 | 5001 Kbps | video=5001000 |
avc3.64002A | 690 Segments | ~44m09s
13:19:53.341 INFO : Vid *CENC 1280x720 | 3302 Kbps | video=3302000 | avc3.64002A
13:19:53.341 INFO : Vid *CENC 960x540 | 2200 Kbps | video=2200000 | avc3.4D401F
13:19:53.341 INFO : Vid *CENC 768x432 | 1300 Kbps | video=1300000 | avc3.4D401F
13:19:53.341 INFO : Vid *CENC 640x360 | 900 Kbps | video=900000 | avc3.4D401F |
13:19:53.342 INFO : Vid *CENC 480x270 | 550 Kbps | video=550000 | avc3.4D401F |
13:19:53.342 INFO : Aud *CENC audio_1=96000 | 96 Kbps | mp4a.40.2 | 2CH | 1325
Segments | ~44m09s
13:19:53.342 INFO : Aud *CENC audio=64000 | 64 Kbps | mp4a.40.5 | 2CH | 1325
Segments | ~44m09s
13:19:53.342 INFO : Sub textstream_dut=1000 | nl | stpp.ttml.im1t | 1309
Segments | ~43m37s
13:19:53.343 INFO : Parsing streams...
13:19:53.346 INFO : Selected streams:
13:19:53.346 INFO : Vid *CENC 1920x1080 | 5001 Kbps | video=5001000 |
13:19:53.346 INFO : Sub textstream_dut=1000 | nl | stpp.ttml.im1t | 1309
Segments | ~43m37s
13:19:53.346 INFO : Save Name: ep_02
13:19:53.350 INFO : Start downloading...Vid 1920x1080 | 5001 Kbps |
video=5001000 | avc3.64002A
13:19:53.350 WARN : When CENC encryption is detected, binary merging is
automatically enabled
13:19:53.548 WARN : Type: cenc
13:19:53.548 WARN : PSSH(WV):
IidwbC1iZDg1NzZlMy0yYTJkLTRjZGMtYTZkMS1iZTk5Zjc5OT Q5Y2JI49yVmwY= 0Bps --:--:-- ⣷
13:19:53.549 WARN : KID: 2b72b3a79b0bd9b6a19fc34dde309a76
13:19:53.549 WARN : Reading media info...
13:19:53.711 INFO : [0x1]: Video, h264 (avc3), 1920x1080
13:20:41.010 WARN : ep_02.mp4 => ep_02.copy.mp4
13:20:41.012 INFO : Binary merging...
13:20:43.071 INFO : Decrypting...
13:20:43.073 INFO : Start downloading...Sub textstream_dut=1000 | nl |
stpp.ttml.im1t| 5001 Kbps ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 100% 1.54GB - 00:00:00
13:20:43.109 WARN : Reading media info...
13:20:43.258 INFO : [0x1]: Data, none (stpp) (default)
13:21:10.290 WARN : Extracting TTML(mp4) subtitle...
13:21:10.809 INFO : Binary merging...
13:21:10.812 WARN : ep_02.copy.mp4
13:21:10.812 WARN : ep_02.nl.srt
13:21:10.812 WARN : Muxing to ep_02.MUX.mp4
13:21:11.000 WARN : [h264 @ 0x13e904950] top block unavailable for requested
intra mode -1
13:21:11.000 WARN : [h264 @ 0x13e904950] error while decoding MB 0 0, bytestream
25804
13:21:11.008 WARN : [mov,mp4,m4a,3gp,3g2,mj2 @ 0x13e904080] Incorrect number of
samples in encryption info
13:21:11.008 WARN :
/Users/zhiyun/Downloads/N_m3u8DL-RE_Beta_osx-arm64/ep_02.copy.mp4: Invalid data
found when processing input
13:21:11.016 WARN : Cleaning files...
13:21:11.028 INFO : Done
First thing first,
--key "2B72B3A7-9B0B-D9B6-A19F-C34DDE309A76" is totaly wrong set.
Use decryption key not kid, something like --key kid:keyLast edited by naim2007; 4th Feb 2023 at 10:43.
PSSH: AAAAT3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAC8iJ3BsLWI0YTVmZmQ2LTBlZDktNDFhNi1iOGVjLTVlYTgyZDYzYTNjNEjj3JWbBg==
Code:mpd_url: https://remix.vrtcdn.be/content/vod/pl-b4a5ffd6-0ed9-41a6-b8ec-5ea82d63a3c4/pl-b4a5ffd6-0ed9-41a6-b8ec-5ea82d63a3c4_drm_67460275-af84-4dbf-8130-1abf8cd2e7f5.ism/.mpd
and feed all info to N_m3u8DL-RE.exeCode:--key 800840d1f5eb8a344a020c01d41469d7:8a3385a9fe2b439ace70b6117175d2cf
Code:N_m3u8DL-RE.exe --auto-select --save-name "set anyname here" "https://remix.vrtcdn.be/content/vod/pl-b4a5ffd6-0ed9-41a6-b8ec-5ea82d63a3c4/pl-b4a5ffd6-0ed9-41a6-b8ec-5ea82d63a3c4_drm_67460275-af84-4dbf-8130-1abf8cd2e7f5.ism/.mpd" --tmp-dir tmp --key 800840d1f5eb8a344a020c01d41469d7:8a3385a9fe2b439ace70b6117175d2cf -M format=mkv:muxer=mkvmerge
Thank you for your help! Now I got some issue while trying extract subtitle from the video, could you please help me check with it?
The subtitle worked well in my video player but when I extracted it the size of the srt/vtt file was only 1kb containing about 10 sentences. I did some search on google but it seemed that nobody got similar problem. Thank you again in advance!
zhiyun@ZhiyuntekiMacBook-Pro N_m3u8DL-RE_Beta_osx-arm64 % ffprobe -v error -of json ep_01.mp4 -of json -show_entries "stream=indextream_tags=language" -select_streams s
"programs": [
"streams": [
"index": 1,
"tags": {
"language": "nld"
zhiyun@ZhiyuntekiMacBook-Pro N_m3u8DL-RE_Beta_osx-arm64 % ffmpeg -i ep_01.mp4 -map "0:1" output.nld.srt
ffmpeg version 5.1.2 Copyright (c) 2000-2022 the FFmpeg developers
built with Apple clang version 14.0.0 (clang-1400.0.29.202)
configuration: --prefix=/opt/homebrew/Cellar/ffmpeg/5.1.2_4 --enable-shared --enable-pthreads --enable-version3 --cc=clang --host-cflags= --host-ldflags= --enable-ffplay --enable-gnutls --enable-gpl --enable-libaom --enable-libaribb24 --enable-libbluray --enable-libdav1d --enable-libmp3lame --enable-libopus --enable-librav1e --enable-librist --enable-librubberband --enable-libsnappy --enable-libsrt --enable-libsvtav1 --enable-libtesseract --enable-libtheora --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libxvid --enable-lzma --enable-libfontconfig --enable-libfreetype --enable-frei0r --enable-libass --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libspeex --enable-libsoxr --enable-libzmq --enable-libzimg --disable-libjack --disable-indev=jack --enable-videotoolbox --enable-neon
libavutil 57. 28.100 / 57. 28.100
libavcodec 59. 37.100 / 59. 37.100
libavformat 59. 27.100 / 59. 27.100
libavdevice 59. 7.100 / 59. 7.100
libavfilter 8. 44.100 / 8. 44.100
libswscale 6. 7.100 / 6. 7.100
libswresample 4. 7.100 / 4. 7.100
libpostproc 56. 6.100 / 56. 6.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'ep_01.mp4':
Metadata:
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
date : 2023-02-04T09:23:59.5705190-08:00
encoder : Lavf59.27.100
Duration: 00:39:33.23, start: 0.000000, bitrate: 4999 kb/s
Stream #0:0[0x1](und): Video: h264 (High) (avc3 / 0x33637661), yuv420p(progressive), 1920x1080 [SAR 1:1 DAR 16:9], 4995 kb/s, 50 fps, 50 tbr, 19200 tbn (default)
Metadata:
handler_name : VideoHandler
vendor_id : [0][0][0][0]
Stream #0:1[0x2](nld): Subtitle: mov_text (tx3g / 0x67337874), 0 kb/s (default)
Metadata:
handler_name : SubtitleHandler
Output #0, srt, to 'output.nld.srt':
Metadata:
major_brand : isom
minor_version : 512
Stream #0:0(nld): Subtitle: subrip (default)
Metadata:
encoder : Lavc59.37.100 srt
Stream mapping:
Stream #0:1 -> #0:0 (mov_text (native) -> subrip (srt))
Press [q] to stop, [?] for help
size= 1kB time=00:36:09.45 bitrate= 0.0kbits/s speed=4.11e+05x
video:0kB audio:0kB subtitle:1kB other streams:0kB global headers:0kB muxing overhead: 92.005608% -
thanks sir, but I need subtitles for all 6 episodes.. could you please do me a favor?
keys
ep1
800840d1f5eb8a344a020c01d41469d7:8a3385a9fe2b439ac e70b6117175d2cf
ep2
2b72b3a79b0bd9b6a19fc34dde309a76:5a60993f460e07e76 f9d9831914be3aa
ep3
b5539c2e8791345374a610cc8048bdb2:40bc7c1d88faa32f6 f4603ac39c6cd0a
ep4
579271d0396af256e948111854269866:16698cbc22fede903 fa43714174fd4a8
ep5
e535293a74d0d1011cb7479c76b6561f:b11362c251fd35047 aef172852a44243
ep6
63848f63c57220115759c846e151344f:9eddebc7a9f8767f6 e8e4bf334e9456e
mpds
ep1
https://remix.vrtcdn.be/content/vod/pl-b4a5ffd6-0ed9-41a6-b8ec-5ea82d63a3c4/pl-b4a5ffd...2e7f5.ism/.mpd
ep2
ep3
https://remix.vrtcdn.be/content/vod/pl-317b1481-bcf0-48b8-8e23-ff8edf3db9c2/pl-317b148...8b27b.ism/.mpd
ep4
https://remix.vrtcdn.be/content/vod/pl-26121d99-c392-4a4b-9ddd-410d3d9c0e38/pl-26121d9...371e9.ism/.mpd
ep5
https://remix.vrtcdn.be/content/vod/pl-ff888cb0-aa4e-4ffc-b356-30686292bbdc/pl-ff888cb...be6f9.ism/.mpd
ep6
https://remix.vrtcdn.be/content/vod/pl-3529fd11-7709-41bd-a4db-386a63f1823e/pl-3529fd1...53261.ism/.mpd -
I checked this subtitle I found there were also some sentences missing.
for example the timestamp jumps from 6' to 13'
18
00:06:08,613
00:06:10,453
op de spelers en de staf.
on the players and staff.Edit Subtitle
19
00:13:18,693
00:13:22,733
Dat Casteels er in de jeugdselecties
op elk vlak boven uitsteekt,
That Casteels excels
in every area in the youth selections,
Really weird. It does work well in media player... -
you can download subtitles only no key need it not encrypt
yt-dlp --allow-u --write-sub --skip-download "MPD URL"
subtitle edit to save srt file and it can remove formatting
AES 128 Key, How do i decrypt or find the key?
By GirlsGill in forum Video Streaming DownloadingReplies: 12Last Post: 12th Feb 2024, 08:03 -
Get KID and key from mpd file
By Deshdeepak in forum Video Streaming DownloadingReplies: 40Last Post: 3rd Dec 2023, 14:21 -
I don't get key with wks-key.
By Brift_Bv in forum Video Streaming DownloadingReplies: 34Last Post: 18th Nov 2023, 03:35 -
No downloader working without key. now getting base64 key string is tough.
By akshaysic in forum Video Streaming DownloadingReplies: 6Last Post: 14th Jan 2023, 10:33 -
How to check KID
By U96 in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2022, 09:51
