  1. Member acusman's Avatar
    Feb 2011
    South Carolina
    I have an AJA LHe-Plus capture card with the KL breakout box for capturing VHS tapes. Getting good results testing the many capture formats it offers, but I'm a little confused on several. Although there is a myriad of capture options for AVC/H.264 and H.265 MP4 capture I have the following settings "allowable" for analog capture under the .MOV format:
    MOV Files
    Apple ProRes 422 (8 or 10-bit options)
    Apple ProRes 422 HQ (8 or 10-bit options)
    Apple ProRes 422 LT (8 or 10-bit options)
    Apple ProRes 422 Proxy (8 or 10-bit options)
    Apple ProRes 4444 (10 or 12-bit options)
    Apple ProRes 4444 XQ (10 or 12-bit options)
    AVID DNxHD HQ
    AVID DNxHD HQX
    AVID DNxHD SQ
    AVID DNxHR 444
    AVID DNxHR 444 12bit
    AVID DNxHR HQ
    AVID DNxHR HQX
    AVID DNxHR LB
    AVID DNxHR SQ
    Mainconcept MOV:
    MC DVCPRO50 NTSC
    "Built-In" MOV:
    8-bit YCbCR
    8-bit BGRA
    10-bit YCbCR
    10-bit BE RGB
    12-bit RGB
    OTHER FORMATS
    MP4 Files (interlaced videos will be captured as progressive):
    AVC/H.264 Low
    AVC/H.264 Med Low
    AVC/H.264 Med
    AVC/H.264 Med High
    AVC/H.264 High
    AVC/H.264 Max
    HEVC/H.265 Low
    HEVC/H.265 Med Low
    HEVC/H.265 Med
    HEVC/H.265 Med High
    HEVC/H.265 High
    HEVC/H.265 Max
    MXF Codecs (4k/UltraHD only - ProRes HQ 8-bit BGR)):
    AVID DNxHD HQ
    AVID DNxHD HQX
    AVID DNxHD SQ
    AVID DNxHR HQ
    AVID DNxHR HQX
    AVID DNxHR 444
    AVID DNxHR LB
    AVID DNxHR SQ
    It is the "Built-In" categories that I'm confused about. I've tried the 8-bit YCbCR format and it produces excellent video but HUGE files (about 80 times the size of h.264 HQ and a little over twice the size of ProRes 422 HQ 8-bit, and 3x the size of ProRes 422 8-bit files. A DVCPRO50 file is a bit less than 1/2 the size of YCbCR.
    I'm assuming that the 8-bit YCbCR is some type of uncompressed codec but can anyone provide a little more detail on the "Built-In" formats above?
    Also, any other user input on settings for VHS tapes, Digital8, Analog8 or MiniDV tapes.
    Just an additional note: my capture card is not compatible with VirtualDub or OBS so I'm trying to work with the AJA options available to me.
    Jan 2016
    Apple ProRes 4:2:2 (8-bit) is the closest to lossless AVI 4:2:2, You don't want to capture and encode on the fly, Capture lossless first and encode later, OBS is never the right tool for analog tapes even if it works.
    D8 and MiniDV are digital formats, use Sclive to transfer them and a firewire connection.
  3. Member acusman's Avatar
    Feb 2011
    South Carolina
    Just a few tests I am running to check output. Four capture versions.
    Using S-Video cable, Panasonic AG-1970 with AVT-1710 TBC running through AJA LHe Plus capture card and breakout box. Capture using AJA Control Room software.
Name:	4-version capture1.JPG
Name:	4-version capture2.JPG
Name:	4-version capture3.JPG
Name:	4-version capture4.JPG
Name:	4-version capture5.JPG
Name:	4-version capture6.JPG
  4. Originally Posted by acusman View Post
    10-bit YCbCR and 8 bit are uncompressed. You want that or a losslessly compressed version of that. Then you filter and encode to produce your final file.
