Depends what model you are talking about, Not all output VHS via HDMI.
Results 31 to 34 of 34
Yeah the output from the HDMI port on them is the same as what goes out the analog outputs. It does however require that whatever they are connected to supports HDCP, so you can't connect that directly to a capture card, you will need something like a hdmi splitter (that skips it) to get around it.
About HDMI splitters removing protection, some info here: https://gleitz-info.translate.goog/forum/index.php?thread/47571-welcher-hdmi-splitter-..._x_tr_pto=wapp
Capturing SVHS using a standard VHS VCR - Is it possible?
By DJ Kris in forum Capturing and VCRReplies: 15Last Post: 4th Jul 2020, 12:00 -
Budget AMD Ryzen build
By kyrcy in forum ComputerReplies: 7Last Post: 2nd Jan 2020, 10:25 -
Budget class D amp
By jamesbowers in forum AudioReplies: 5Last Post: 20th Jun 2019, 13:28 -
VCR on a Budget?
By DiggyDre in forum Capturing and VCRReplies: 6Last Post: 13th Feb 2019, 23:45 -
Best Budget Capture Device
By jackdaws in forum Capturing and VCRReplies: 29Last Post: 26th Feb 2018, 22:41
