  1. I've just captured a tape and when playing the avi file, it has a strange sound that is there throughout the whole capture.
    I've captured from this tape a few times now and never had this noise before. I've just done a quick capture from a different tape and its not present, so I'm guessing that its something wrong with the tape, strange that it was fine last week though?
    Just wondering if anybody knows what this could be?
    Jan 2016
    It's called head switch noise, Happens on HiFi audio only, Try cleaning drum heads, Also if the VCR has the auto cleaning roller remove it.
  3. Manually adjust the tracking.
  4. Originally Posted by dellsam34 View Post
    I’ll give that a go but it seems odd that its only that tape that has the noise. Ive tried 3 other tapes now and they dont have it.
    Also the vcr is brand new out the box, its only had a few hours of use, so Im not sure that they'd be that dirty yet. Out of interest, how often do you advise to clean heads?
    That doesn't make a difference unfortunately.
    Jan 2016
    There is no rules about head cleaning, Some are anal about it and they perform it before each tape transfer and some do it only when a clog is noticed, and a hole lot of choices in between, It's a personal preference.
  6. deleted (wrong thread).
