  1. Hi There:
    Is it better to export your video out of QuickTime as a Toast Ready VCD file or save your file as a self contained movie (I Assume That's What You Do Once You've Synced Your Video And Audio) and drop that into the Toast window and let it convert it for you??
    Or does it matter (i.e. Do They Both Use The Same Conversion/Compression Drivers Anyway)
    Thanks Again
    Coaster Boy
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    It's the exact same thing.
