When i right click on a file name in Firefox and do a search google for it brings me to the google.com site,any way to change it so it brings me to the google.ca site?
Results 1 to 9 of 9
Thought it worked but nope.
Question
Is this behavior just with FF or does it happen with other browsers also? -
I just use firefox,edge doesnt use the google search for.
I think it automatically redirects to your country Google portal. Try typing "about:config" in the URL bar, accept the warning and search for "Google". Make sure the correct country code is shown. You can try changing the search name defaults, I haven't tried it but it might work.
Brian. -
Found that you had to go to settings/search and change default search engine to google.ca,thanks again jagabo.
strange google search response
By vhelp in forum ComputerReplies: 27Last Post: 2nd Sep 2022, 06:47 -
Google OCR
By elyasi in forum Newbie / General discussionsReplies: 9Last Post: 7th Feb 2022, 10:15 -
Google Vignette Ads
By usually_quiet in forum FeedbackReplies: 7Last Post: 27th Mar 2021, 04:36 -
Google sued by DOJ in antitrust case over search dominance
By El Heggunte in forum Off topicReplies: 0Last Post: 21st Oct 2020, 07:07 -
Google Play Store
By Mohamet in forum SubtitleReplies: 6Last Post: 5th Apr 2019, 13:50
