I borrowed a porn DVD from a friend and Im able to rip the vob files ok,(or so it seems) until I go I check the indiviual files and the end of the movie is missing, for instance a 4 hour movie is 2 hours and it gets cut off. Im using sefys guide for making vcd.s (smartripper, dvd2avi and tmpgenc ) any suggestions for different ripper etc
thanks
Results 1 to 9 of 9
Well, grmpy, you should be ashamed of yourself!! That said, try ripping again, but this time using FILES instead of MOVIE (in SmartRipper). SR doesn't select all files if you use MOVIE (just picks the largest one).
Anyway, most porn DVDs are not encrypted (so I've heard), so you may be able to just drag them from your DVD-ROM drive straight to HD > NERO > DVD-R (or process to SVCD, VCD, etc). -
LOL yeah right, you know you found this information out by personal experience :DOriginally Posted by SLK001
Anyway, I just wish my local video stores carried some decent dvd porn titles :wink: -
Well, actually, all of my porn... I-I-I mean all of my NEIGHBOR'S porn is on video tape! (And pretty crappy transfers, at that. So bad, that my capture card won't lock on the sync pulses properly. I have... I mean, HE has some good stuff, too!)SLK001 wrote:
smartripper does choose ALL the vobs in a set....
btw, beware of using file mode in smartripper as it doesn't remove any multi-angles...assuming porn movies have them (dunno...maybe???) -
I'm glad you got my joke but really aren't all of them good if it get's the woman going
We were all NEWBIES once and the only stupid question is the one that's not asked?
Travellers to be searched for porn
By zzyzzx in forum Off topicReplies: 0Last Post: 26th May 2010, 15:01 -
First HD DVD porn goes on sale
By BJ_M in forum Off topicReplies: 20Last Post: 20th Dec 2009, 16:03 -
Free Porn at Wal-Mart!!!!
By zzyzzx in forum Off topicReplies: 12Last Post: 23rd Oct 2009, 06:57 -
Copying Speed Slows Down as Copying Progresses
By Soopafresh in forum ComputerReplies: 3Last Post: 25th Sep 2009, 21:03
