  1. Hi
    and however Im' a cat
    however.
    If possibile I would like to do a batch that encode my .mxf source into 1 final MP4 for whatsapp of 64MB
    whatever the resolution and duration of the source, eventually scaling from HD to SD in case of length of the original video over 3 minutes.
    But the audio part of the final output mp4 file, presumably has to be built and calculated first, so that all the video part corresponds to a precise remaining size/bitrate. For example, if the audio part weighs 3MB, of the 64, it means that the video part can be a maximum of 60-61 MB. However the final file cannot be generated larger than 64MB. Is it possible to do all this in command line and with ffmpeg? thanks
  2. The definition of bitrate is:
    stream size / running time = bitrate
    So get the running time of the video and encode at the required bitrate for your desired stream size.
  3. You already know how to do each of the required steps. Just put them together.
  4. but I'm a ***, for kindness be patient: my limited brain however
    If we consider a source like this:
    https://www.swisstransfer.com/d/5ed752dd-32de-46e9-af42-9ac2425127ed
    is a video MXF file, 566 MB, 1 min 18sec, HD with audio. How to tell to ffmpeg to generate a .MP4 x264 (also without audio) of exactly and not over 60 MB using double pass?
  5. 60000000 bytes * 8 bits per byte / 78 seconds = 6153846 bits per second
  6. wonderful ***
    but :
    for kindness : maybe I need to do some little operations, if possible.
    Supposing a source (not too big files) like this:
    https://www.swisstransfer.com/d/83b7611e-94e2-4ee2-a358-7cfae3ad0cba
    a Source.mkv video file 1920x1080 50i, 1 minutes and 29 second. Audio on 2 track, track 2 don't consider. Track 1 have a L + R channels and is the only to be encode
    my target should be encode the source.mkv in a MP4 file for whatsapp of exactly 63 MB. And where the audio part is something like a 128 kbs VBR stream
    So the commandline for ffmpeg how it should be done?
