Normally I take videos with my phone, drop them into DropBox to get to my PC and then import them into whatever I am using (Vegas MS today)
File appears normally as this ...
[Attachment 68976 - Click to enlarge]
Now today files arrive and appear as
[Attachment 68977 - Click to enlarge]
Which the PC thinks is Audio only.
If I double-click with default player as WMP, it played audio only .... I changed the default player to SPLASH and if I double click I do get audio & video.
However, if I import it into VMS it arrives as audio-only not video
Also tried several converters - non are happy with the files.
Just as part of picture - files play happily on teh phone (Android)
Sample file attached - welcome advice.
Results 1 to 14 of 14
On your phone:
Camera>Settings cog>scroll down to "Videos"
In "Advanced Video Options", turn off the "Reduce File Size", which is a weird way of saying "turn off HEVC format". Turning that off will mean your videos will be recorded in AVC/H264, which is a less-compressed format. File sizes will be bigger but easier for editing.
It is odd that even Microsoft Films and TV won't play that HEVC (it plays OK in VLC Player). There's definitely something odd about that HEVC file.
The HEVCs from my S21 play OK in Films and TV. -
The file played on WMP for me, but it might be because I have LAV filters installed
Rick, (How you doing buddy ?)
Are you saying that VLC does not play that sample 'Pergola.mp4' ?
If so, I find that strange. I am using the same version of VLC and, unless your system details are not updated, the same Win7-64. And it plays just fine.
It also 'played' the HEVC sample. Not great but that is down to my memory-crippled system -
This is a normal h264 video
[Attachment 69130 - Click to enlarge]
The only problem I can see here is the high profile level (Main@L4).
You can try to lower this level a bit, e.g. to 3.1.
You can do this with clever-FFmpeg-GUI, portable, no installation, without recoding.
Load your mp4, click main, click change p-level, set new level to 3.1 and click change level.
[Attachment 69131 - Click to enlarge]
When done, you will find your new mp4 file in the target folder. -
An issue with mp4 decryption
By CrymanChen in forum Video Streaming DownloadingReplies: 16Last Post: 27th Apr 2022, 06:43 -
Stutter issue with MP4 files in Avisynth
By Master Tape in forum EditingReplies: 13Last Post: 26th Mar 2022, 15:12 -
DVD to MP4 issue with handbrake
By Halon in forum DVD RippingReplies: 17Last Post: 12th Dec 2020, 13:35 -
VirtualDub External Encoder AVI to MP4 Issue
By Bassquake in forum Newbie / General discussionsReplies: 12Last Post: 27th Aug 2018, 07:08 -
Interesting MP4 issue
By bakonfreek in forum Software PlayingReplies: 3Last Post: 8th Feb 2018, 13:50
