Hello everyone,
I’m looking for a way to compare 2 (possible) different video streams of the same source via python or another kind of software.
Long story short, I got a WEB rip of a TV show and recently the Blu-Ray got released (with possible corrected animation frames).
Is there any way I can run a script for ep 01 from WEB vs BD and see which frames are different?
Results 1 to 15 of 15
download this: https://files.videohelp.com/u/198160/Comparator.7z , unpack into a directory, select both videos in windows explorer and put them on Comparator.exe,
it is a very early version from a time ago, which I'am finishing into a proper package(slowly), but I bet it will work. Use keys '1' and '2' to switch between clips, spacebar is playback, mouse wheel zooms in and out etc., it is a self sustained package and does not install anything. -
I usually use AviSynth to compare videos. You can stack them side by side or vertically. Or you can interleave frame by frame. The former are good for seeing the videos in motion or for quick scans for missing segments. The latter for pixel peeping between the two videos (open the script in an editor like VirtualDub2 and use the arrow keys to move back and forth between the same frame of two videos, it's easy to see even minute differences).
Thanks guys!
I was actually wondering if it’s possible to do it automatically, without me being needed to go frame by frame. -
Avisynth, vapoursynth, but you mentioned python so perhaps working with it is no problem, you can choose python and using modules skimage, opencv and plotlib to have visual graph output:
Code:#python3 #variation for link below #https://stackoverflow.com/questions/56183201/detect-and-visualize-differences-between-two-images-with-opencv-python from skimage.metrics import structural_similarity import cv2 import numpy as np import matplotlib.pyplot as plt def process_img(image1, image2): # Convert images to grayscale image1_gray = cv2.cvtColor(image1, cv2.COLOR_BGR2GRAY) image2_gray = cv2.cvtColor(image2, cv2.COLOR_BGR2GRAY) # Compute SSIM between the two images, score is between 0 and 1, diff is actuall diff with all floats (score, diff) = structural_similarity(image1_gray, image2_gray, full=True) return score * 100 vidcap1 = cv2.VideoCapture(r'D:\videos\vid1.mp4') vidcap2 = cv2.VideoCapture(r'D:\videos\vid2.mp4') y_axis = [] frame_number = 0 while True: success,image1 = vidcap1.read() if not success: break success,image2 = vidcap2.read() if not success: break score = process_img(image1, image2) frame_number += 1 y_axis.append(score) x_axis = list(range(0, frame_number)) plt.title("differences between videos") plt.xlabel("Frames") plt.ylabel("% of difference") plt.scatter(x_axis, y_axis, s=10, c='red') plt.show()
Structural Similarty (SSIM) is somewhat useful for comparing different encodings of the exact same material. It's typically used to compare a source and (re)encoded video, as a gauge of how well the encoded video matches the source, or which of two (re)encoded videos better matches the source. It's not useful for finding if a video has extra or deleted scenes -- except that the SSIM will be very bad past the first addition/deletion.
Question is quite vague, not sure what "corrected animation frames" means.
That plot would just reveal first jump, where things go wrong, or he could set a threshold to look for that change and then stop it, because if frames are added or deleted, it is not useful after that spot.
But there would certainly be differences at the beginning of videos, so some manual sync would be needed. Or maybe that was a part of the question, to come up with a solution to find first sync frames, mark it and then look for differences. If found, mark it and then again look for a sync again. Repeat. That sounds pretty complicated. -
There will also be problems if the two videos have different framing, different frame sizes, bit depths, color formats, etc.
If you want an off-the-shelf SSIM (or PSNR, VMAF, etc.) file compare utility you can use ffmpeg (command line).
drag/drop batch file for psnr:
Code:ffmpeg -i %1 -i %2 -lavfi "[0:v][1:v]psnr" -f null -
Code:ffmpeg -i %1 -i %2 -lavfi "[0:v][1:v]ssim" -f null -
Code:ffmpeg -i %1 -i %2 -filter_complex libvmaf=n_threads=8 -f null -
https://github.com/DeltaFlyerW/AudioMatchVideoCut
This script compares two video with their audio hash, and outputs the difference in the time lines. I wrote this to detect time-line displacement caused by censored video cuts on anime in China. In the early stages of development, I attempted to implement it using video frame-by-frame comparison, but abandoned it due to performance and frame difference issues. -
I doubt you'll be able to reliably automatically detect such differences between streaming and Blu-ray versions of a show. The differences due to the encoding and other processing are likely to be larger than any extra details.
oh,
This is such a cool thing on forums in general, to see that left hook coming from nowhere. In this case thinking to find video cuts and then hearing , hey, it is just the same and perhaps easier to check the audio instead ...
Mp4Box - Output is generated without frame Width, frame height & frame rate
By Saptarshi in forum Newbie / General discussionsReplies: 0Last Post: 25th Nov 2022, 08:27 -
I-frame cutting sometimes results with video start at previous I-frame.
By TempUser_ in forum EditingReplies: 3Last Post: 25th Oct 2021, 01:40 -
Aegisoft: view video frame by frame
By Bonnie25 in forum SubtitleReplies: 1Last Post: 15th May 2019, 18:05 -
Best way to compare two videos (original and converted) for frame shift?
By Bencuri in forum Video ConversionReplies: 4Last Post: 27th Aug 2018, 21:06 -
Frame Rate, Bitrates ans Frame by frame comparison
By novreis in forum Newbie / General discussionsReplies: 1Last Post: 5th Feb 2018, 17:40
