Hi! I'm a newbie here, hope I get help
What kind of artifact is it and is it possible to fix this? I circled it in red, but in general it appears throughout the frame, I don't even know how to describe it correctly
[Attachment 68922 - Click to enlarge]
Thanks for any help!
You need to supply a sample of the original MPEG 2 video. But it looks like poor scaling or poor deinterlacing. Maybe an NTSC to PAL conversion?
For the flickering applying QTGMC(InputType=1) after normal QTGMC() should help.
Playing around using https://pastebin.com/5fuhVHXx
Cu SelurLast edited by Selur; 28th Jan 2023 at 09:48. Reason: attached the output of the script
users currently on my ignore list: deadrats, Stears555, marcorocchini -
Yes, QTGMC() smooths out the aliased edges, reduces the buzzing, and keeps the smooth motion.
Help needed to identify type of noise
By DDrumD in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jan 2022, 17:56 -
identify field order and frame type of VOB file with DGINdex
By RogerTango in forum DVD RippingReplies: 6Last Post: 12th Dec 2021, 11:06 -
So I captured some PAL VHS footage at 30 fps and...
By Soundguy in forum Capturing and VCRReplies: 71Last Post: 20th May 2021, 15:35 -
Color moire/flickering in PAL footage
By voyagerhelp in forum Video ConversionReplies: 5Last Post: 9th Jan 2021, 23:17 -
VHS PAL Capture - Very minor pink noise appearing on sports capture
By Robertp in forum RestorationReplies: 12Last Post: 9th Nov 2018, 19:50
