Hello,
I have a 97-episode TV animation series with five different audio tracks and subtitle tracks,
I want to remove all other tracks than English, but not one by one.
Is there a way to remove all tracks from episodes at once?
Thanks in advance.
If mkv output is ok, use mkvtoolnix.
If you want mantain other containers, use clever Ffmpeg-GUI. -
I do remember a batch script was developed by ?, so you would have to do a search for batch edit MKV files script. Of course the English language track in all 97 eps would have to be the same track number ie say track 3. You can load in multiple episode in to MKVToolNix and they appear as tabs, so you just work left to right but it is simply a manual method but take a look at this to see if it suits your needs
https://www.videohelp.com/software/mkvbatchmultiplexSONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
I can load multiple files into mkvtoolnix, but all the work to remove the undesired tracks has to be done manually for all the episodes though.
[Attachment 68941 - Click to enlarge]
The English tracks unfortunately differ from one file to another, and therein lies the rub.
Isn't there any way to determine the track by language code? -
" The English tracks unfortunately differ from one file to another, and therein lies the rub.
Isn't there any way to determine the track by language code? "
Possibly if they are correctly labelledSONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
Converting multiple video files to MKV using MKVToolnix
By pcmacbob in forum Newbie / General discussionsReplies: 5Last Post: 7th Sep 2022, 14:24 -
Batch edit with MKVToolnix not working?
By Greatestguru in forum Video ConversionReplies: 1Last Post: 4th Sep 2020, 04:42 -
Edit Meta Data, MKVToolNix GUI, Commands?
By Alieo in forum Blu-ray RippingReplies: 1Last Post: 23rd Mar 2019, 16:13 -
Joining MKV with subs in multiple languages with MKVToolnix
By Tedbax in forum EditingReplies: 4Last Post: 3rd Mar 2019, 04:53 -
Batch header edit with MKVToolNix GUI?
By everapt in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2018, 12:07
