    Oct 2019
    I'm having a strange issue where trying to use EZKeepGrain is causing the following issue:
    Before
    [Attachment 68912 - Click to enlarge]
    After
    [Attachment 68913 - Click to enlarge]
    I tried getting rid of the SourceMatch, Lossless, and changing the presets and no matter what it still has the same result. I also tried adjusting the settings that go with EZKeepGrain and nothing made a difference. Does anyone know what is causing this? I'm using a standard HuffYUV AVI input and never had this issue before (although, I never used EZKeepGrain). I read everything on the QTGMC wiki about EZKeepGrain but nothing appeared to explain this. Rendering the file also resulted in the black video.
    Is EZKeepGrain even worth using?
  2. Likely culprit is old version of some buggy dependency
    Update some of your plugins such as masktools2 , mvtools, and/or QTGMC script version
    Oct 2019
    Thanks!!, I updated those and the QTGMC update fixed it.
