Hi folks,
I’m using a Blackmagic DeckLink Mini Recorder 4K in my desktop PC to record video over HDMI. I am focused for the moment on recording 4K HDR input, which the Blackmagic card is capable of recording. It comes with the Blackmagic Media Express software for recording, which is a very basic Windows application that simply allows you to record with some basic settings from what I can tell.
In the Media Express settings, the “File Format” options are:
AVI 8-bit YUV
AVI 10-bit YUV
AVI 10-bit RGB
AVI Motion JPEG
QuickTime Uncompressed 8-bit YUV
QuickTime Uncompressed 10-bit YUV
QuickTime Uncompressed 10-bit RGB
DPX 10-Bit RGB
The recording works fine in terms of capturing the video and audio and saving to the desktop’s internal SSD. The problem has been trying to get HDR to work. The only file formats that seem to capture and playback HDR are the QuickTime options listed above. The others (I haven’t tested DPX) are washed out SDR (input is sending HDR). The QuickTime files on the other hand though are prohibitively massive ultimately leading to full storage or a crash (1 Gbit/second bit rate) and the input is not anywhere near this bitrate.
The AVI Motion JPEG option seems to be the only option that saves files in a reasonable/functional size (~100 mbit/second bitrate) but does not save with HDR. The Blackmagic card purportedly works with other recording software, and so far I have tried OBS, which works but does not record HDR.
I’m basically trying to figure out if there is a way/software that will record the 4K HDR input but in a reasonable/functional size. Any ideas?
Thanks!
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 1 of 1
DataVideo HDR-1 Part of the Capture Chain?
By companda in forum CapturingReplies: 0Last Post: 4th Aug 2022, 00:17 -
Any solution to transform HDR video to Youtube compatible HDR?
By Truthler in forum Video ConversionReplies: 2Last Post: 20th Jul 2021, 11:37 -
Alternative capture software to Blackmagic Media Express?
By digitalfreaknyc in forum CapturingReplies: 6Last Post: 8th Jun 2020, 20:23 -
MPC-BE HDR media in non HDR screens. Oversaturated picture.
By Zapa in forum Software PlayingReplies: 4Last Post: 29th Dec 2019, 11:31 -
Betacam Capture With BlackMagic UltraStudio Problems
By dellsam34 in forum CapturingReplies: 5Last Post: 21st Feb 2019, 14:57
