Hello, searched about this issue but couldn't find any topics related to this, so figured that might as well ask this over here first.
So, I have this problem with some executable Bink-videos that RADVideoTools refuse to convert into MP4 for some reason. I did already email them, but decided to ask about this over here too, if there's better/newer tools for these files. Conversion to AVI works fine, but results unnecessarily massive files (well over 4Gb per video). Did check out some converter tools already, but as guessed, they don't understand those executable videos at all.
Any solutions to this? Also, this topic can be moved to better area and removed if needed etc.
If your files are bink v1 (not bink2) you can use clever FFmpeg-GUI.
Load your file, click main, click encode video stream, click keep resolution, leave all settings as the are, click encode.
If done, click encode audio stream, click go to the encoder, leave all settings as the are, click encode.
If done, click multiplex, select the streams shown in green, deselect all other streams, set mp4 as container, click multiplex. Done. -
Tested, didn't work, threw this error:
[Attachment 68863 - Click to enlarge]
Checked the file with RADVideoTools, here's the information:
[Attachment 68864 - Click to enlarge] -
Can you go back to normal bik file from exe with RADVideoTools?
If so, retry with the bik file. -
Start the RAD Tools, highlight the exe, click Mix in Sound, insert a - (minus sign) at sound file to mix, a -1 at Mix into what Bink..., set the ouputfile and click mix.
[Attachment 68865 - Click to enlarge]
Done.
Then, for the conversion, use CRF 20 for the video conversion in clever FFmpeg-GUI.
Can't find a way to convert to Bink losslessly
By SlyCooperReloadCoded in forum Video ConversionReplies: 10Last Post: 3rd Mar 2022, 14:33 -
Bink Video plugin for Premiere Pro
By PU User in forum EditingReplies: 6Last Post: 7th Jul 2021, 04:58 -
Trouble de-interlacing Bink video from a game
By SlyCooperReloadCoded in forum Video ConversionReplies: 2Last Post: 19th May 2021, 14:19 -
How to use youtube-dl or streamlink Windows executable on cbs.com?
By FredThompson in forum Video Streaming DownloadingReplies: 9Last Post: 2nd Mar 2019, 11:52 -
youtube-dl Download Manager No Longer Contain Any Executable Files!?
By meeshu in forum Newbie / General discussionsReplies: 2Last Post: 15th Mar 2018, 22:36
