Hi all,
I am trying to convert a MOV and MP4 file to XDCam HD 422 format
Below are the requirement I got from a studio.
Format: MP4
Codec : XDCAM HD 422
Frame rate: 25
Fps Bit rate: 50Mbit/s CBR
Sound: Stereo track 1 & 2, 10dp to -12dp4
Aspect: 16:9 aspect ratio, 1920*1080 pixels
Explanation:
I did some animation in AE and have exported files as MOV and MP4. Currently I am figuring out how to conver Mov or Mp4 file into give format. I have tried Encoder but it exports .mxf. Is there way to wrap these .mxf to .mp4 or some other workflow to achieve give format?
Also I am not familiar to codecs so any help will be appreciated.
Thanks in advance
hey Prowo, thanks for helping out!
I did try the command but is gives out error
"Could not find tag for codec pcm_s16le in stream #1, codec not currently supported in container
Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
Error initializing output stream 0:2 --"
is there anything that can solve this?
Also same error is given out in clever FFmpeg -
That works!!
Thank you so much!
It solved my mov problem.
PorWo you did a lot actually but is there other solution to get working for xdcam codec working on mp4?
I know its lot to ask but I am kinda new to xdcam outputs. -
iPhone MOV to mp4, upside down??
By tpapictures in forum Video ConversionReplies: 4Last Post: 13th May 2020, 20:02 -
FFMPEG Prores mov to 4K HDR Mp4 or Mkv
By ceppu36 in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2019, 15:58 -
How to tag/metatag MP4, AVI, MOV, WMA ?
By pacman10 in forum Newbie / General discussionsReplies: 16Last Post: 11th Dec 2018, 01:28 -
Cannot convert 4K MKV to MOV or MP4 without color issues
By JDLangton in forum Video ConversionReplies: 9Last Post: 12th Nov 2018, 22:38 -
MOV/MP4 editing sofware?
By taboo in forum EditingReplies: 4Last Post: 16th Aug 2018, 06:23
