Hi,
I'd like to auto replace certain words
for example "Tim's" > "Teams"
Do i have to go to menu's and select "Replace" or there is a way to do this automatically?
You can use "replace all" to change all occurrences of some word to another
Thanks! but this would require repeated action every single time, - is there a way to have "auto correct applied" automatically?
If Tim’s is a word you want to replace in every subtitle you come across you can Subtitle Edit’s Options > Settings > Word lists. Enter Tim’s in the left hand box at the bottom of OCR fix list and Teams in the right hand box. The word will change when you do Tools > Fix common errors, you need be sure to check the box ‘Fix common OCR errors (using OCR replace list)’ before you select the Next> button.
subtitle edit is auto breaking lines
By cocowash in forum SubtitleReplies: 1Last Post: 6th Apr 2020, 08:23 -
Multiple replace with Subtitle Edit
By [ss]vegeta in forum SubtitleReplies: 4Last Post: 1st Mar 2020, 04:20 -
Subtitle Edit 3.5.7 suddenly stopped auto-translating...
By zeus182 in forum SubtitleReplies: 9Last Post: 31st Aug 2019, 08:01 -
Auto Translate is not working on Subtitle Edit 3.5.9
By Giri in forum SubtitleReplies: 0Last Post: 5th Aug 2019, 06:37 -
Find and replace only in selection, Subtitle Edit
By SUWII in forum SubtitleReplies: 6Last Post: 21st Dec 2018, 02:14
