Thousands of Mkv Files Available How to convert multiple audios and subtitles to hls with ffmpeg sample link
https://demos.jwplayer.com/hlsv4-audio-tracks/
Do you think what is, essentially, your 3rd topic on the same subject will reveal answers not addressed in the other two ?
In fact multiple topics on the same Q. will, ultimately, draw the attention of admin.
But by all means report this reply. It will only serve to alert admin to the duplicate threads -
FYI
I have not reported anything.
But if you go back to your other topics you will see a possbile solution. How the respondent did this I know not. Maybe that solution is not what you require since the subs, if I understand correctly, have to be converted outside the video stream and the m3u8 will link them together.
But under this reply you will see links to similar threads and these may well assist.
Download HLS video using FFMPEG with separate video and audio URLs?
By oschrndz in forum Video Streaming DownloadingReplies: 2Last Post: 15th Dec 2020, 13:53 -
mkv to hls from ffmpeg
By b2kguga in forum Video ConversionReplies: 4Last Post: 15th May 2020, 03:41 -
Help Recording m38u HLS aac stream with ffmpeg (streamlink works)
By Neilyboy in forum Video Streaming DownloadingReplies: 2Last Post: 10th Apr 2020, 06:51 -
HLS with multiple audio streams
By Derel in forum Video Streaming DownloadingReplies: 16Last Post: 1st Jul 2019, 20:05 -
Looking for HLS dvr or HLS time-shift record
By Alien51 in forum Newbie / General discussionsReplies: 0Last Post: 15th Mar 2018, 23:48
