  1. I try to convert a divx to mpeg 2 with TMPGEnc .
    Everything work just fine. But if I try now to view the mpeg file with WMP I have only audio, no video. I don't think is a problem with Windows Media Player because when I try to cut this file with TMPGEnc I have the same problem. Just audio, no video.
    When I try to burn a SVCD with Nero I don't get any message saying that the file is corrupt or anything but I don't want to burn a CD whitout being sure that it will work on my DVD Player. Hitachi P-415
    Please help.
  2. Do you have mpeg2 codec installed? this codec will play mpeg2 files on Windows Media Player - http://www.vcdhelp.com/vcdtools.htm
    o(-_-)o---------------------------------------o(-_-)o
  3. Do you have mpeg2 codec installed? this codec will play mpeg2 files on Windows Media Player - http://www.vcdhelp.com/vcdtools.htm
  4. Do you have mpeg2 codec installed? this codec will play mpeg2 files on Windows Media Player - http://www.vcdhelp.com/vcdtools.htm
  5. Do you have mpeg2 codec installed? this codec will play mpeg2 files on Windows Media Player - http://www.vcdhelp.com/vcdtools.htm
  6. No. I don't think so.
    Thanks budy. Appreciate your help. :lol:
