I know you can stabilize the screen, but I have a source that looks like its flashing brighter and darker rapidly every frame as its playing.
Video sample
https://mega.nz/file/0ghHFKbT#Q6YJRwsPB9AT_S1DPLhd57AY_Ufzn_3_xKKXuWM9gY8
Are there any avisynth filters to level that out or help make it less obvious?
Filters under http://avisynth.nl/index.php/External_filters#Luma_Equalization or Small_Deflicker should help.
Cu
Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
Upload sample to this forum,you can go to 500MB in size,nobody wants to go to mega for files.
afaik. those filters to not denoise
I think all the successful deflicker filters use some form of temporal pixel averaging. This is because different parts of the frame often flicker differently (as does your video).
A mild SMDegrain can help without damaging the picture too much:
You might try following up with a grain restoration function.Code:SMDegrain (tr=3, thSAD=500, refinemotion=true, contrasharp=false, PreFilter=4, mode=0, truemotion=true, plane=4, chroma=false)
Sample with SMDegrain added:Last edited by jagabo; 22nd Jan 2023 at 09:24.
I think you can fix that quite well, although the non-standard frame rate of animation might cause some problems.
First, you may only need to use Deflicker. I use this on film all the time. I have queued up my restoration before/after examples to a scene in which was "brightness stabilized" with just deflicker:
https://www.youtube.com/watch?v=tBAHzO7rJS0&t=116s
In addition, there is a little-known effect of using the MVTools2 denoising which, with the correct parameter, can also remove a lot of noise. The only downside is that it makes MVTools2 run at about 1/4 it's normal speed. The "secret" is to use dct=1 in all MAnalyze calls. You use MAnalyze before the call to MDegrain. Since QTGMC uses MDegrain, you can look at the documentation for how to feed it dct=1 (it uses the default of dct=0), or you can go into the AVSI QTGMC code and change it directly.Last edited by johnmeyer; 22nd Jan 2023 at 22:07. Reason: clarification
Stabilization question
By killerteengohan in forum RestorationReplies: 18Last Post: 30th May 2020, 15:00 -
By killerteengohan in forum RestorationReplies: 1Last Post: 8th Dec 2019, 11:34 -
VSDC Stabilization
By Penny666 in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jun 2019, 10:07 -
Fixing video after stabilization
By marius2du in forum Video ConversionReplies: 9Last Post: 11th Feb 2019, 15:53 -
Stabilization Tools Pack v2.1
By Dogway in forum RestorationReplies: 92Last Post: 27th Jul 2018, 00:57
