I don't know if this can screw up what I have. But I've been adjusting start times and such repeatedly with no seeming movement. I Remember that Subtitle Edit has somewhere a preset minimum time between subs. But where is that setting?
I don't know how it effects pauses between dialog that should remain consistent-- just certain dialog could come on more rapidly a bit.
Visually, I see the problem.
Results 1 to 16 of 16
Not sure what you are asking but to set start times is in the synchronization settings.
I don't think this is a settting that needs to be touched,
the defaults are fine. The OP must be talking about something else, but he described it poorly -
I agree it's hard to describe some of this.
Using synchronization > Start earlier and do the rest of the lines is fine. I can see the
calculation change after the selected line. But then I see a slight delay between speeches of dialog.
Overnight I thought it might be the amount of time the title is onscreen. But that wouldn't account for the delay or does it? This occurs at a second adjustment in the SRT. I had to do it a second time after an act interval. Again, the subs are from a different source of the same recording but edited slightly differently. It's a hack to get subtitles on a higher quality video source than they had come from.
If I went back and watched very carefully from the beginning and saw the same effect, could it be an issue for frame rate? I know that the question has been asked: Can SE change framerate and the answer was it could. But all these might be nits not able to be fixed.
Not much better at describing this time.
Sounds like your subtitle isn't the right version since it doesn't line up with speech after adjusting the timing.
Well the English is close enough to be usable esp for hearing impaired, the small amount I think will be acceptable.
However I may have to just abandon adjusting the two additional foreign languages of Ukrainian and Russian. These were in the
same original group. But I don't know either language. My best guess is one version includes a credit roll and the video does not.
-- > This needs a separate question but what if the proper start time goes into negative numbers? In other words the subtitle file is longer than the video? -
Means it's not the correct subtitle.
Yes I think you are right it's a mismatch and I'm just wheel spinning.
But I have all or most of the original content-- just not in the same resolution. I'll look and see how those
load into the old version.
thanks to all who answered. -
Last thing on this because I noticed something. The original content video with sub was the 29.97 fps US standard.
The larger video I wanted to add the sub to is the Euro standard for these at 25 fps. Does that mean anything to Subtitle edit for synchronizing subs? -
Possibly but not necessarily so. Standards conversion doesn't always change the video's running time
I think davexnet is right. It indeed depends and you should compare playing times.
Check if the 25 fps video runs as long as the 29.97 one. If so, no framerate sync is necessary.
Chances are the 25 fps video runs about 4% faster, in which case you're possibly dealing with filmbased "sped-up to PAL" video. Here, a 23.976 to 25 fps sync should do a proper job (Synchronization --> Change frame rate).
Next to framerate syncing, SE always offers the option to do a visual sync. Works like a charm. -
Haven't done this last thing yet, but how does the fps change engage?
Load SE > General Settings > 23.976 to 25 , then load
the SRT, MKV, and Audio? Or does it matter? -
Open the srt with subtitle edit,go to synchronization/change frame rate 23.976 to 25 hit ok and save as.
I did give it a try and it is something I did not know from SE. But I was not getting anything better.
Thanks again to those who answered. I have something usable, just not as close to the spoken lines as I thought was possible.
This is across two separate versions etc. I'm going to let it go at that. I have done line by line edits and that
might work but I have other subs projects.Last edited by loninappleton; 24th Jan 2023 at 22:32.
Change start time in Subtitle Edit
By loninappleton in forum SubtitleReplies: 3Last Post: 20th Jan 2023, 01:27 -
Subtitle Edit option to select minimum spaces between
By loninappleton in forum SubtitleReplies: 7Last Post: 19th Aug 2022, 12:51 -
Subtitle Edit - compare subs
By maudit in forum SubtitleReplies: 0Last Post: 3rd Apr 2022, 05:13 -
Subtitle Edit not showing subs in video and waveform
By evayor in forum SubtitleReplies: 3Last Post: 5th Jun 2020, 01:31 -
This dummy can't sync subs with Subtitle Edit or Subtitle Workshop :-(
By inspector_plodder in forum SubtitleReplies: 6Last Post: 24th Aug 2018, 18:33
