Hi,
is there a way to quickly extract subtitles from a dvd? Several software (for example SubRip) let you extract subtitles from the VOB file, but the process is very long because you have to correct each letter, number and symbol that the software doesn't recognize and, if the movie is long enough, it takes over an hour. It would be easier to transcribe the subtitles directly!
I wonder if there are faster methods to extract subtitles. Do you have any ideas?
Thank you in advance!
Luca
Hi,
You could use "Subtitle Edit v3.6.10".
You can also use "MeGUI" to extract the "Sub/idx" files, and then use "Sub Extractor v1.0.3.2d" and convert to ".srt" extension.
Hope this helps. -
Converting DVD subpictures to a text based format, such as srt, requires optical character recognition (OCR). There is no way around that. However, normally it should not take an hour to OCR a DVD. More like 5-10 minutes. Maybe Subtitle Edit works better for you.
Alternatively, you could keep the subtitles in binary format, such as sub/idx, which is done by just extracting them from the VOBs, and use that for playback. -
Olá,
Eu moro no "Brasil".
I'll write in portuguese.
Com esse aplicativo, talvez resolva o seu problema "Sub Extractor v1.0.3.2d".
Basta extrair as legendas "Sub/idx" e converter com esse aplicativo.
É rápido a conversão. -
I gave up ocr. Now and days I just burn them in to keep proper placement and spelling.i use bdsup2sub to adjust position and colors as needed. For ocr when needed I use subtitleedit as it works for me in Linux. Yes I mean burn as not selectable, but part of the image. Works for my case as every device on my server will have the subs exactly where I wanted
if all else fails read the manual
How Can HardSub Subtitles Extract?
By cinamews in forum SubtitleReplies: 7Last Post: 25th Sep 2022, 06:33 -
Does anyone know how to extract subtitles from .ts?
By ALUOp in forum DVB / IPTVReplies: 48Last Post: 27th Jul 2022, 00:39 -
Subtitles to extract
By ecolek in forum Video Streaming DownloadingReplies: 2Last Post: 14th Feb 2021, 05:45 -
How to extract and convert DVD subtitles on linux ?
By precipizio in forum DVD RippingReplies: 0Last Post: 5th Jan 2021, 03:32 -
extract idx subtitles from dvd
By Shingen36 in forum SubtitleReplies: 1Last Post: 24th Jul 2019, 01:03
