I install the card and let it look for a driver on the disc I got with the PCTV card. While XP is installing the driver (4.2), it craps out and gives me an "invalid data" error. Any help appreciated.
Hi--I just installed this card using WIN XP pro--I downloaded the drivers from Pinnacles web site-The version is 5.01--I didn't think the drivers on the CD were for XP only WIN2000. Everything is working fine even the remote. Check out the web site--Good luck Cweig
Hi there,
Forget about the disc that came along with the card.
Goto pinnacle's homepage below and download the lastest drivers 5.01 for your card.
http://www.pinnaclesys.com/docsupport1.asp?division_id=1&langue_id=2&product_id=103&pr...pro&page_id=62
That may sort your problem out. -
I also have the 5.01 drivers. How do I install starting with these. It is an executable file. The OS shouldn't recognize it as a driver. I figured I had to install with included drivers and then update with 5.01.
Hi--When I downloaded 5.1 from the web site I "saved to disk" in a folder I called PCTV in MY Documents so I would have it if I need to reinstall it. Then I just double clicked on the folder and the software installed. This is all I've used -nothing from the cd-and the card works great. Good luck--PS I have also read you might have problems if you have earlier versions still installed on your PC--so I would remove everything associated w/ PCTV PRO and start fresh w/ the 5.01
pinnacle pctv 310i
By marc21782000 in forum Capturing and VCRReplies: 10Last Post: 4th Jan 2010, 02:30 -
Pinnacle PCTV HD Pro Stick, my experience
By vhelp in forum DVB / IPTVReplies: 46Last Post: 14th Oct 2009, 19:36 -
Capture with DC 10 Pinnacle Card with OS Win 2k and Pinnacle studio11
By fjmr in forum Capturing and VCRReplies: 2Last Post: 7th Apr 2008, 17:02 -
Audio problems with Pinnacle PCTV HD Pro Stick.
By cactusjack310 in forum AudioReplies: 0Last Post: 21st Jan 2008, 17:16 -
Which is best, Pinnacle 110i or PCTV Pro PCI
By brvignesh in forum Capturing and VCRReplies: 23Last Post: 28th Nov 2007, 22:40
