Results 1 to 12 of 12
    Mar 2013
    Argentina
    Hi:
    Well I managed to do almost everything right except some step, and for that reason I'm getting a wrong/shorter video. BTW, I use a free account. I can stream the complete actual video with it.
    Could someone please tell me why I'm getting the wrong video?
    I actually need to learn what I'm doing wrong to correct it, because I'd love to get many of those episodes to cut clips of artists I love, instead of having to screen capture them (something that actually works with Firefox + Movavi Screen Recorder), but I'd really love to get the source files, not screen capture quality.
    Thanks so much in advance!
  2. all right.
    from ffmpeg shot you have:
    video
    Duration: 00:49:04.56, start: 1906.560000, bitrate: 1678 kb/s
    audio
    Duration: 00:49:04.59, start: 1906.567256, bitrate: 69 kb/s
    so, it seem your video and audio have the right length
    have you tried to play with VLC only decryption video and decryption audio? the length is right?
    then is ffmpeg issue when join audio+video
    Mar 2013
    Argentina
    Mmm... I didn't try playing the individual decrypted files.
    Let me try that
  4. 'yt-dlp' doesn't work here. Use other tools.
    Mar 2013
    Argentina
    all right.
    video
    audio
    Decrypted audio lasts 17:18 --> https://we.tl/t-pwr0XPymmj
    Decrypted video lasts 49:02 (yet not the correct video...) --> https://we.tl/t-UabR9U6cns
    Mar 2013
    Argentina
    I know no other.
    Could you please name one?
    Thanks!
  7. N_m3u8DL-RE (search on github)
    put all keys on txt file (rename as key.txt) then run:
    N_m3u8DL-RE -M format=mp4 --key-text-file key.txt "https://mpd_link"
    or -M format=mkv
    if you prefer mkv video final file
  8. or also use clever to join video+audio (an amazing ffmpeg GUI, thanks to ProWo)
    but you have incorrect audio file, so need to download again the right audio file only
    Mar 2013
    Argentina
    thanks so much, @lomero.
    No idea how to download the correct audio, but I'll give this a try.
  10. N_m3u8DL-RE "mpd_link"
    download audio only (use arrow key to select audio only)
    [Attachment 68735 - Click to enlarge]
    then merge audio/video with ffmpeg or clever
    Mar 2013
    Argentina
    Thanks so much !!!!!!!
