is anyone able to use this in windows 11? I installed some drivers for it and device manager states working properly (shows both dazzle auido and dazzle video) I can also select the dazzle in virualdub 2 and amarectv and vlc media player but I don't get any video or sound. In vlc I do get sound but it's really choppy. I have my camera permission in windows turned on and it shows that all the apps have accessed the camera (dazzle). I'm thinking the old dazzle just doesn't work with windows 11? Just curious if anyone is still using one. Also if you are capturing (I'm trying to capture some laserdiscs) what are you using? Thanks
The quality of these is bad anyway.
Not worth using.Want my help? Ask here! (not via PM!)
Dazzle DVC100 not capturing anymore on Windows 10
By kernelfree in forum Capturing and VCRReplies: 150Last Post: 10th Apr 2024, 16:34 -
Can a Dazzle DVC100 deteriorate in performance?
By John2583 in forum Capturing and VCRReplies: 28Last Post: 27th Feb 2023, 14:36 -
Dazzle DVC100 not capturing anymore on Windows 7
By Roland in forum Capturing and VCRReplies: 8Last Post: 1st Apr 2022, 06:04 -
No sound with Dazzle DVC100 from Panasonic camera through SVideo
By tbentinck in forum Capturing and VCRReplies: 4Last Post: 4th Jun 2019, 18:03 -
Help! Dazzle DVC100 capture over-exposed/too bright.
By m-acrylic in forum Capturing and VCRReplies: 9Last Post: 18th Dec 2018, 14:25
