Whether it's VOSK or Whisper, how is anyone to know when the model is updated and improved for accuracy?
Download the database then, and download it now (same level/version) and then do a bitwise compare. Or file timestamp compares.
Or read any accompanying changelogs.
That's about it.
Whisper sounds VERY interesting...if you have lots of time to spare/wait, and you are using English language. Otherwise, still not ready for prime time (too high error rates, holes in model/stats logic)
Scott -
The models are often held though (at least with Subtitle Edit) in uncommon file locations. At least so-called roaming locations are obscure to me.
Where I personally alter subtitles made with the AI tools, it's still by hand. I have only done a couple of plays from start to finish as a hobby for some favorites.
Do the models have a specific file extension? Using SE makes any of this obscure since loading the models is inside SE. It's a great convenience but
doing these sorts of things discussed requires more detail. I use the Everything file search tool. That works well for locating things.
Ok, I did a practice looking up VOSK and Everything found it. VOSK does have a version number .22 on it's zip file. Whisper seems to go by date stamp--
last one 22 11 16.
vosk machine learning and alphacepei models updates
By loninappleton in forum SubtitleReplies: 4Last Post: 21st Aug 2023, 06:34 -
A guide to generating subtitles through Whisper AI
By lordlance in forum SubtitleReplies: 1Last Post: 12th Jan 2023, 21:44 -
Subtitle Edit 3.6.10 new version with Whisper option
By loninappleton in forum SubtitleReplies: 33Last Post: 18th Dec 2022, 15:24 -
Best text-to-speech voice?
By Aludin in forum AudioReplies: 13Last Post: 31st Jul 2019, 09:20 -
Panasonic HC-VX1 - UK/Aust model or US model?
By caix in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 3rd Aug 2018, 01:55
