Hey everyone, I’d REALLY like to use DVrescue to capture my tapes as it really seems like the most robust and modern piece of windows based software for the task. WinDV just isn’t cutting it, and Scenalyzer is problematic at best.
The problem for me, at least at this particular point in my trials and tribulations of dealing with MiniDV tapes, is that it’s not recognizing my FireWire connection to the camera. Whereas other programs, like the aforementioned WinDV and Scenalyzer are.
I am running a relatively new Windows 11 PC (a DIY build put together during the pandemic, around the AMD 5950X)
Since I have an AMD system, thunderbolt is not usable or featured on my motherboard (Asus crosshair VIII formula) so I have a Sony HDR-HC7 hooked up to the FireWire port on a FireWire PCI-E card. And of course I’ve already went through the step of installing the legacy driver.
It doesn't look like capturing with windows is supported yet: https://github.com/mipops/dvrescue/issues/445
Ahhhh that would explain it, thanks! Their own help/documentation page seemed to indicate that this should currently be possible, for some reason. I might just hold off on transferring anything for the time being then. Current solutions just don’t make this a feasible project for me to tackle but hopefully they get transfer working on windows soon. I’d also be willing to try the Linux build but that will have to be an experiment for another day.
Does DVrescue currently have the ability to capture via CLI? And preferably with an on-screen preview? Long shot but figured I’d ask
Probably not, there are other open issues around supporting capture on windows and linux. For now it looks like you can only capture with a Mac although you should be able to use the other functionality on windows once you have a capture.
Bummer, Linux and Mac are all I really have access to at the moment. Maybe I’ll suck it up and buy a Mac just for this. It seems like it may have the best software for detecting and repairing errors upon transfer.
Canon HV20 firewire connection quit working (W10)
By chipgooding in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 28th Jun 2021, 09:58 -
LG BP350 not recognizing chapters from a mp4 or mkv file.
By DaveB69 in forum DVD RippingReplies: 10Last Post: 5th Nov 2020, 19:24 -
BD3D2MK3D not recognizing 3D from MakeMKV
By sardon68 in forum Video ConversionReplies: 1Last Post: 26th Aug 2019, 07:05 -
DVD Recorder not recognizing dvds
By JDiane in forum DVD & Blu-ray RecordersReplies: 29Last Post: 15th Apr 2019, 15:02 -
MINIX NEO U9-H no longer recognizing external HDD
By CaptainCatholic587 in forum Media Center PC / MediaCentersReplies: 15Last Post: 7th Sep 2018, 01:28
