how to download this link via vinetrimmer- https://www.bbc.co.uk/iplayer/episode/m001h0vq/eastenders-12012023
i try with
its doesnt work, there is no season or episode Number, only just date 12/01/2023 so anyone know how to download itCode:poetry run vt dl -w S01E01 ip b006m86d
i know it can download with yt-dl but i need with vinetrimmer cos it give 1080p
You can download this in 1080p with get_iplayer
Code:get_iplayer --get 2497 --tv-quality fhd
Windows installers available from here:Code:Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.2 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 28 min 59 s Bit rate mode : Variable Bit rate : 5 116 kb/s Maximum bit rate : 12.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 50.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.049 Stream size : 1.04 GiB (97%) Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Codec configuration box : avcC Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : mp4a-40-2 Duration : 28 min 59 s Bit rate mode : Variable Bit rate : 128 kb/s Maximum bit rate : 131 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Stream size : 26.5 MiB (2%) Language : English Default : Yes Alternate group : 1
https://github.com/get-iplayer/get_iplayer_win32/releases/tag/3.30.0
You need ffmpeg in your iPlayer Recordings directory
https://www.mediafire.com/file/mv3ffex88q6z3ef/ffmpeg.exe/fileLast edited by codehound; 15th Jan 2023 at 06:44.
@codehound, cheer mate. i forget about get iplayer. been use this years back. thank you bring it up and remind me :thumb up:
convert video by cmd
By grabyea in forum Video ConversionReplies: 7Last Post: 30th Sep 2021, 05:55 -
BBC iplayer download dimensions
By David Banner in forum Video Streaming DownloadingReplies: 1Last Post: 17th Sep 2021, 14:26 -
Is there a way to schedule a download at a certain time from cmd?
By lfer94 in forum Video Streaming DownloadingReplies: 8Last Post: 7th Jul 2021, 22:02 -
Youtube-dl How to download this video in this quality from Iplayer ?
By Fredmason in forum Video Streaming DownloadingReplies: 2Last Post: 20th May 2019, 07:10 -
CMD error with youtube-dl
By king maker in forum Video Streaming DownloadingReplies: 12Last Post: 6th Mar 2019, 01:47
