Hello, I have discovered my long-time lost camera Sony Handycam dcr-hc90e. I charged it and tried to record something. When watching recorded cassette footage in the camera the screen is damaged with grey lines and the footage is not flawless. I put another cossette with the footage I made like 15 years ago and tried to watch the footage and it has the same problem. So I assume it should not be a problem that occurs while recording rather when playback. Or may I be wrong? What would you advise me to do?
Thank you very much!
https://youtube.com/shorts/67fTbyHGa_I?feature=share
Possible one of the heads is dirty or broken. I don't know how the image raster is formed in DV in relation to head A and head B, If it is laid as shown in the video sample then possibly one head is not reading the signal. If it plays/records analog tapes try an analog tape and post a sample.
its a common issue. the drum is dirty, just clean it with 100% Alcohol.
Alcohol is much efficient than a clean tape.
help with capturing dv footage from sony handycam
By mtntrogger in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 23Last Post: 11th Mar 2024, 00:30 -
Sony Video8 Handycam shows horizontal lines at bottom during playback
By Deichbruch in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 15th Jan 2023, 12:35 -
Problems in capturing DV from Sony Handycam DCR-HC90
By His LA Dudeness in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 6th Oct 2022, 17:07 -
Sony Handycam DCR-DVD105 Disc Error - Please Help
By studiowork in forum DVD & Blu-ray RecordersReplies: 1Last Post: 1st Sep 2020, 06:45 -
How to reset Sony Digital8 Handycam? (DCR-TRV520)
By Vitality in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 24th Jan 2019, 20:13
