Hi all,
I have a folder with images that I've extracted from one video.
The resolution for each image is 5760 X 2880.
All images are in the following format:
I tried couple of different ways to stich them:
Using CPU - libx264
Worked well but the speed is about X0.05 only.Code:ffmpeg -r 30 -f image2 -s 5760X2880 -start_number 1 -i "AllFrames/out-%d.jpg" -vframes 119 -vcodec libx264 -crf 25 -pix_fmt yuv420p "/AllVideoChunks/Chunk_1.mp4"
Using GPU - h264_nvenc
Working very fast and high quality, but the problem is that I can't use it for images and output bigger then width 4096Code:ffmpeg -r 30 -f image2 -s 4000X2000 -start_number 1 -i "AllFrames/out-%d.jpg" -vframes 119 -vcodec h264_nvenc -gpu 0 -preset slow -b:v 75M -pix_fmt yuv420p"/AllVideoChunks/Chunk_1.mp4"
Using GPU - hevc_nvenc
Working X10 more then the CPU at the speed of X0.5, good quality, but the problem is that I can't use it in normal players (can't play it in Unity)Code:ffmpeg -r 30 -f image2 -s 5760X2880 -start_number 1 -i "AllFrames/out-%d.jpg" -vframes 119 -vcodec hevc_nvenc -gpu 0 -preset slow -b:v 75M -pix_fmt yuv420p"/AllVideoChunks/Chunk_1.mp4"
Is there another video codec that can work on GPU that support more then 4K resolution?
Can I transform the 'hevc_nvenc ' output to 'h264' on GPU in higher resolution? should I do this transformation on CPU?
Results 1 to 12 of 12
General rules for stitching series of images is here https://trac.ffmpeg.org/wiki/Slideshow - seem you are following them (more or less)
libx264 is with default parameters, to speed-up encoding you may consider using different libx264 settings: https://trac.ffmpeg.org/wiki/Encode/H.264
Seem there is HW limit on accepted resolution in your NVEnc - verify this with NVEnc supported resolution https://en.wikipedia.org/wiki/Nvidia_NVENC if you HW don't support resolutions higher than resolution of your files then you need to use or CPU encoding, reduce input pictures resolution or replace GPU.
You need to verify if your decoder support such video resolution and video encoding type - usually HW decoders are limited by so called Profile and Level.
Also SW decoders may have some limitations (such as memory limitations)
https://en.wikipedia.org/wiki/High_Efficiency_Video_Coding_tiers_and_levels
https://en.wikipedia.org/wiki/Advanced_Video_Coding#Profiles
This depends purely on HW capabilities of your graphic card - as you not providing any information on HW then there is no way to answer for your questions. You may think about using embedded GPU in your CPU (if your HW has this GPU present - usually some Intel and AMD CPU's provide such functionality).
Whenever you are using GPU for video encode please verify drivers version installed in system - they may be additional dependencies there. -
Am going to suggest a different strategy: go back and start over. I am betting that the original video was NOT of 5760x2880 resolution (which is ~double the native rez of 4k cameras). Assuming this,
Either
re-extract at the original resolution (using something not lossy, like png), stitch, and and THEN do what necessary aspect change to 2:1 that you want. Much less problematic afa computer constraints.
Or
Use an NLE on your original video, marking your still extraction points as single frame clips in a clip library, and just edit, never leaving the NLE. 1000 clips is not that much, and with keyboard shortcuts/macros, you would already be finished (plus you would have complete control over the order). And then aspect adjustment.
I bet there is a story behind that choice of resolution...
Scott -
Use hevc_nvenc instead of h264_nvenc. It allows up to 8K (depending on which generation GPU you have).
Hi Guys,
Thank you all for your input! what a strong community to be part of!
I would dive deep into the references!
Some details about my machine:
GPU - I'm using 2 graphic cards (RTX 3080 & RTX 3070).
CPU - Intel Xeon W-2102
Ram - 32GB
SSD - 1T
The video input is 5.7K, using camera: Insta360 X2.
After stitching the 2 side video into a 360 video I'm getting a 5760x2880 @ 30FPS video.
If there is a way to programmatically (I can code ) change the 'timespan' for each frame by a choice that would be super awesome and will solve all my problems
Any suggested solution for this case? -
I'm not clear on what you're asking about "timespan", but you can change the timestamps - this controls the display time per frame
Indirect method is by changing the framerate . -r 30 means 30/1 fps . So the display time per frame is ~33.33ms - but that is essentially constant frame rate (CFR) because every frame has the same delta (that is, if the container timebase allows enough precision)
If you need different timestamps per frame, look at v2 or v1 timestamp formats - they are described in the mkvmerge documentation
16.1. Timestamp file format v1
This format starts with the version line. The second line declares the default number of frames per second. All following lines contain three numbers separated by commas: the start frame (0 is the first frame), the end frame and the number of frames in this range. The FPS is a floating point number with the dot '.' as the decimal point. The ranges can contain gaps for which the default FPS is used. An example:
# timestamp format v1
assume 27.930
800,1000,25
1500,1700,30
16.2. Timestamp file format v2
In this format each line contains a timestamp for the corresponding frame. This timestamp must be given in millisecond precision. It can be a floating point number, but it doesn't have to be. You have to give at least as many timestamp lines as there are frames in the track. The timestamps in this file must be sorted. Example for 25fps:
# timestamp format v2
0
40
80
To add the timestamp file, you can use mkvmerge for MKV container, or mp4fpsmod for MP4 containerLast edited by poisondeathray; 14th Jan 2023 at 15:09.
OMG 😱
I think V2 is exactly what I need!
This will probably going to save me a 5 hours pipeline of video manipulation.
I'll read more about that, and see if I can write the needed coded for my used case, to set those timestamp as I need.
In my use case, what I did in a very 'painful way' is a pipeline of:
1. Extract of all images.
2. Stiching together 100 frames and set a different FPS for this piece.
3. Stiching together all the pieces about.
4. And the I got a movie with a dynamic FPS.
I abused the FPS value to change the timestamp values for each frame but in a not accurate way.
Changing the timestamp per frame might give me a more control about the quality of the video as a 'whole', the video speed effect.
I'll keep you guys updated once I'll read about it more and implement it in my use case. -
Both NVidia cards are using Ampere series so HEVC with resolution up to 8192x8192 should be supported in HW NVEnc accordingly to NVidia.
Check graphic driver version and used ffmpeg revision - generally you should always use latest drivers and ffmpeg build.
Seem your CPU is not equipped with onboard GPU and as such there is no QuickSync there.
Seem hevc_nvenc as jagabo suggest is best in your case, alternatively you may consider to keep jpeg (after converting it to mjpeg) - this will be fastest way to deal with your source. -
pandy thanks a lot for your input.
I'm going to heavily use my video card for video editing.
Does the "QuickSync " give a significant boost?
" you may consider to keep jpeg (after converting it to mjpeg) "
What is mjpeg? I'm extracting image (jpeg) and them combining them to mp4 videos -
Thank you all for answering and helping me with this subject.
I really appreciate your help with regards to my questions
Wishing you all a great year
Does larger GOP length affects video?
By Anonymous543 in forum Newbie / General discussionsReplies: 12Last Post: 8th Dec 2021, 00:24 -
Creative video from still images
By drummachinecomplex in forum Newbie / General discussionsReplies: 9Last Post: 21st Jul 2020, 06:25 -
How to turn images into video in bulk?
By vmackey in forum EditingReplies: 1Last Post: 26th Sep 2019, 10:43 -
Converting (?) Video "Larger" (Aspect Ratio), (Quality);
By VideoInfo in forum Video ConversionReplies: 4Last Post: 28th Mar 2019, 23:31 -
Images to Video
By idanad in forum EditingReplies: 5Last Post: 18th Mar 2018, 10:30
