Somebody in my family ripped some old VHS tapes to AVI files before tossing the tapes. They didn't do any clean up, such as trimming the ends, for example, and I'd like to losslessly do that.
I believe most any free NLE software would work, if I'm not mistaken. OpenShot, ShotCut, Kdenlive, DaVinci Resolve --- any of those to particularly avoid? or to go for?
Thanks!
What type of "AVI" ? (What video compression used ?)
vdub2 is a good choice for AVI -
Dunno what video compression was used for these but they are huge, as in 20-30GB each.
VirtualDub2 it is --- thank you for the info, friends. -
You can use mediainfo (view=>text) for more info on the codec /compression used. It's important because it might limit you to specific frames where you can cut ("keyframes") . If it's an I-frame only (keyframe only) format, you are not limited - you can cut "anywhere" .
To set stream copy, make sure you have video=>direct stream copy , and audio=>direct stream copy selected -
Huge? All depends on the duration, and your expectations.
30GB for 2 hours is ~35Mbps. Standard SD DV is 25Mbps (more when you add container and Type2), so not so unusual.
Simple editing/cutting software for .mkv files?
By rotchild in forum Newbie / General discussionsReplies: 5Last Post: 21st Jan 2022, 03:20 -
best easy and free to use photo editing software
By mol3000 in forum ComputerReplies: 10Last Post: 1st Aug 2021, 09:24 -
Any free software to convert .rec files (from the Topfield PVR) into MP4?
By Gameshow Host in forum Video ConversionReplies: 16Last Post: 8th May 2021, 16:28 -
Need free editing software with specific features
By Mahsidivad in forum EditingReplies: 2Last Post: 10th Dec 2020, 16:58 -
[SOLVED] Recommended Windows laptop for office + light video editing?
By yetanotherlogin in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2019, 16:19
