I record the desktop with a lossless codec (FSV1) and would like to achieve a similar quality when encoding with x264. Below you can see the images of the original capture and the one from the encoding
Original
[Attachment 68651 - Click to enlarge]
Encoded
[Attachment 68652 - Click to enlarge]
As You can see, the icons are not as crisp and vivid like the original capture. These are my Handbrake settings
[Attachment 68654 - Click to enlarge]
Video is normally encoded as YV12 (YUV 4:2:0). That means the chroma channels are half the width and height of the luma channel. For example, a 1920x1080 video will have a 1920x1080 luma channel (greyscale) and two 960x540 chroma channels (colors that are added or subtracted from the luma to produce the final on-screen colors). The reduced chroma resolution will always blur sharp colored edges like that.
You can avoid that by encoding without chroma subsampling, using YV24 (YUV 4:4:4) or RGB (4:4:4). But whether that is suitable depends on your application. If you want videos that play on most devices you cannot use those.
How to correct screen recording display PC to avoid flickering over video?
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 24th May 2020, 14:42 -
How do you lose quality when upscaling?.
By Felow in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2020, 23:49 -
Do you lose quality if you encode with the same bitrate or more?.
By Felow in forum Newbie / General discussionsReplies: 21Last Post: 22nd Feb 2020, 20:31 -
Recording Desktop: Multiple Windows and Context Menus
By scarecroe in forum Video Streaming DownloadingReplies: 7Last Post: 12th Feb 2020, 07:20 -
Question About Recording Video Desktop?
By MadMaxnightRider in forum Video Streaming DownloadingReplies: 13Last Post: 31st Dec 2019, 23:36
