    Jan 2023
    Minnesota
    I used to listen to The Morning Show with Dale Connelly and Jim Ed Poole. It was discontinued in 2008. I have a few episodes I downloaded to listen on my podcast app on my old, old phone. And now those are the only ones I have. I don't know if it's the fact that my computer doesn't have Adobe Flash or what.....but now I can't access anything after I finally dug up the buried website on the Way Back Machine archive.
    Website:
    https://minnesota.publicradio.org/radio/programs/morning_show/listings/2007/03/26/index.shtml#wed
    Some skits are available here - but they are just the skits from the last week of the show. Someone else might enjoy listening: https://podcasts.apple.com/us/podcast/mpr-skits-from-the-morning-show/id104720092
    And another website link with some RTSP links that I have no idea to access either:
    http://music.minnesota.publicradio.org/programs/morningshow/features/
    I found the forum after finding this old thread (https://forum.videohelp.com/threads/365508-Solved-How-to-download-radio-show-Prairie-Home-Companion) for Prairie Home Companion.
    Thanks a bunch!
    Jan 2023
    Minnesota
    Thank you, LZAA.
    Jan 2023
    Minnesota
    If anyone knows how to listen to older than 2007, 2008 I'm still wanting to listen to those. Thanks!
  4. First let me take this opportunity to thank jimdagys for his great contribution to the topic
    Thank you jimdagys
    This seems to be the same as what jimdagys pointed out
    https://forum.videohelp.com/threads/365508-Solved-How-to-download-radio-show-Prairie-Home-Companion#post2330575
    use the following url:
    http://167.88.156.221/phc/2014/04/05/phc_20140405_128.mp3
    So you can use the following url as a pattern to download any show ( replace x with show date in proper format as shown in above examples.
    http://167.88.156.221/phc/xxxx/xx/xx/phc_xxxxxxxx_128.mp3
    but now a little variation is required
    from: https://download.stream.publicradio.org/phc/2001/02/24/phc_20010224_128.mp3
    to : https://play.publicradio.org/api-2.0.1/o/phc/2001/02/24/phc_20010224_128.mp3
    https://play.publicradio.org/api-2.0.1/o/phc/yyyy/mm/dd/phc_yyyymmdd_128.mp3
    to download use aria2c
    a little more technical in order to do it automatically.
    curl the url https://www.prairiehome.org/shows/page/xxx.html and grep all the "class=.mod_header. href=". Now curl all the ref links and grep the .mp3 links. Use aria2c to download all the episodes.
    Jan 2023
    Minnesota
    Hi, jack_666
    So, I can view the old webpages - for example - https://minnesota.publicradio.org/radio/programs/morning_show/listings/2007/03/19/index.shtml#wed - which displays the playlists and has a link that goes to the the first hour of the The Morning Show - for example the original link that would have played: http://www.publicradio.org/tools/media/player/minnesota/radio/programs/morning_show/2007/03/19_ms1 (it would have played via a flash player)
    I tried using this root (I don't know a better word for it) from the PHC thread:
    and adjusted to:
    https://play.publicradio.org/api-2.0.1/o/minnesota/radio/programs/morning_show/2007/03/19_ms1.mp3
    And tried adjusting the format to mimic PHC in case they had standardized to something different from original:
    https://play.publicradio.org/api-2.0.1/o/minnesota/the_current/programs/2007/03/26/mor.../03/26_ms1.mp3
    The Morning Show is not The Prairie Home Companion - so the "phc" needs to be changed and I'm not sure if I'm having no luck because the file doesn't exist anymore or if I'm doing it wrong.
    Pic of the links I'm trying to figure out, in case it makes it more clear.
Name:	mpr morning show.JPG
  6. Apologies for my misunderstanding. You are correct. All that I wrote refers to The Prairie Home Companion.
    With respect to your link and your query
    My opinion is that the links doesn't exist anymore.
    You will need to find a site for the Morning Show similar to that for the Prairie Home Companion.
