Hi,
I have tried different software but all of them convert the video too, any solution to just add the sub?
I usually use Movavi but if I add the subs it transforms the file from 311MB to 1.18GB leaving the same video settings
thx
For mp4 sub has to be converted to mov_text.
Sub/idx is incompatible with mp4.
If you want sub, then remux to mkv.Last edited by ProWo; 10th Jan 2023 at 15:13.
If you don't want to change the size of the file just put the mp4 plus subtitle file in a MKV container using MKVToolNix. Just drag and drop the files into the main window. Quality and size In = Quality and size Out.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
The subs need to be in srt format. Add a copy of ffmpeg.exe to the folder.
Subtitles-Add-Track-to-MP4 v04.cmd
Cheers.Code:@echo off :: Video 'track name.mp4' must have matching 'track name.srt' if not exist New\ md New :: Add forced .srt subtitle track. for %%a in ("*.mp4") do if exist "%%~na.srt" ffmpeg.exe -i "%%a" -sub_charenc ISO-8859-1 -i "%%~na.srt" ^ -map 0:0 -map 0:1 -map 1:0 -disposition forced -avoid_negative_ts 1 -max_interleave_delta 0 ^ -c:v copy -c:a copy -c:s mov_text -metadata:s:s:0 language=eng -threads 0 -y "New\%%a"
Add mp4 output on x264 compile
By naoto89 in forum Newbie / General discussionsReplies: 17Last Post: 9th Jul 2020, 16:56 -
Add Audio to MP4 without re-encoding
By paulmolive in forum MacReplies: 6Last Post: 21st Apr 2020, 16:59 -
Stuck in trying to add .ass subtitles to MP4 video
By cgkas in forum Newbie / General discussionsReplies: 6Last Post: 27th Apr 2019, 11:24 -
How to make exact copy of a mkv/mp4... add subtitles
By jagman911 in forum Video ConversionReplies: 2Last Post: 3rd Dec 2018, 12:29 -
Add GPS to mp4
By hereforthevideohelp in forum Newbie / General discussionsReplies: 4Last Post: 19th Feb 2018, 08:48
