hello everyone
it's my first post here in the forum.
i use streamlink last version installed with : apt install streamlink
command i run :
~# streamlink "http://url-of-the-live-video.m3u8" best --ffmpeg-dkey "the dycrypte key here"
i get this error
usage: streamlink [OPTIONS] <URL> [STREAM]
streamlink: error: unrecognized arguments: --ffmpeg-dkey
thanks for help in advance
The error is clear --ffmpeg-dkey is not a valid argument for streamlink.
You haven't mentioned what you are trying to do, where you got the command from or why you think that should work..... -
your problem is that you used the standard version of streamlink ...
try this one: https://github.com/sunghome/streamlink_optionalkey
Need Help Opening this MPD with FFmpeg
By sowie in forum Video Streaming DownloadingReplies: 0Last Post: 28th Jun 2021, 11:05 -
Help with ffmpeg and mpd please
By Chris91 in forum Video Streaming DownloadingReplies: 10Last Post: 24th May 2021, 02:00 -
Streamlink + ffmpeg error: Pipe copy aborted
By Beta2k in forum Video Streaming DownloadingReplies: 16Last Post: 30th Nov 2020, 16:10 -
Help Recording m38u HLS aac stream with ffmpeg (streamlink works)
By Neilyboy in forum Video Streaming DownloadingReplies: 2Last Post: 10th Apr 2020, 06:51
