  1. Hi,
    I face a problem that is probably easy to solve, but I don't know how.
    In Subtitles Edit 3.9.10, I try to break a line: I want the subtitles to be displayed on 2 lines on the same TV screen.
    To do so, I place the cursor in the appropriate line of S.E., I hold "Shift" then I press "Enter", and S.E. indicates the break by showing <br /> in this line: see the "break in SE.jpg" screen capture.
    The problem is that in the film with burn-in subtitles, the line is not broken, and "<br />" is displayed like if it is part of the subtitle: the line is not broken in two parts: see the "in the film.jpg" screen capture.
    How should i proceed ?
    Thank you
Name:	break in SE.JPG
Name:	in the film.JPG
  2. Member Ennio's Avatar
    May 2005
    Netherlands
    Try "Ctrl + Enter".
  3. Great: it works !
    Thank you very much
    canada
    Just wanted to point it's Subtitle Edit 3.6.10,not Subtitle Edit 3.9.10.
    Dec 2001
    Holland
    Just press "Enter"?
    Works on 3.6.4 which I use.
  6. I'm a Super Moderator johns0's Avatar
    canada
    Have you got options/settings/general max number of lines set to 2?
