  1. Hey guys, hope you all are well. I downloaded this video through a torrent and I keep getting these errors when I open it using vlc or potplayer
    Codec not supported:
    VLC could not decode the format " " (No description for this codec), or
    encv video decorder required to play this file
    Media Info:
    General
    Unique ID : 321511466479200362876117139947763233149 (0xF1E0DB27C57F2E20AB115EC167DF717D)
    Complete name : C:\Users\Hp\DOWNLO~1\_FREEC~1.COM\_FREEC~1.COM\_FR EEC~1.COM\2 - Python Introduction\6 - How To Run Python Code.mp4
    Format : Matroska
    Format version : Version 4
    File size : 72.4 MiB
    Duration : 4 min 53 s
    Overall bit rate : 2 070 kb/s
    Encoded date : UTC 2023-01-02 01:26:10
    Writing application : mkvmerge v57.0.0 ('Till The End') 64-bit
    Writing library : libebml v1.4.2 + libmatroska v1.6.4
    FileExtension_Invalid : mkv mk3d mka mks
    Video
    Format : V_QUICKTIME
    Codec ID : V_QUICKTIME
    Bit rate : 2 006 kb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 30.000 FPS
    Bits/(Pixel*Frame) : 0.032
    Stream size : 70.1 MiB (97%)
    Default : Yes
    Forced : No
    Audio
    Format : AAC LC SBR
    Format/Info : Advanced Audio Codec Low Complexity with Spectral Band Replication
    Commercial name : HE-AAC
    Format settings : Explicit
    Codec ID : A_AAC-2
    Bit rate : 62.7 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 23.438 FPS (2048 SPF)
    Compression mode : Lossy
    Stream size : 2.19 MiB (3%)
    Default : Yes
    Forced : No
    Errors : Missing ID_END
  2. Copy the file to a root location (g.e. D:\) and retry.
  3. upload your video to some server (like mega or other) and share link
    Dec 2021
    england
    yep i did once with streamfab, vlc wont play cos of "Format : V_QUICKTIME
    Codec ID : V_QUICKTIME" so i redownload it again to get AVC, it play fine
