hi, I'm experiencing a weird situation with a mux i'm doing.
In few words, I usually mux the dvd audio with an HD encode.
I always used makemkv to create an mkv of the DVD, then I used to extract audio, subs and chapters from it.
But this time the DVD is strange, makemkv created 3 separated files instead of an unique file, MovieA+MovieB+endcredits.
At this point, in order to get the dvd audio as unique files, I changed software, I used DGIndex,
that despite it gave me an unique video and unique audio files, it does not handle chapters and subs.
so, I used mkvtoolnix and appended MovieA+MovieB+endcredits into a single file and I've extracted the chapters and the subs.
I fixed some chapters titles and they are now fine.
Now I've troubles with idx/subs, they have been extracted, and when I mux them I can see them in mpc-hc,
but if I try to load them into Subtitle Edit, in order to convert them into sup or OCR them into srt, I just cannot, cause they look empty, no images, just timings.
how is it possible? can I please have some help?
here's the idx/subs: https://www.dropbox.com/sh/ke22baijjsb3q09/AABuKPbnkcF_hkLy3GR9HE2ia?dl=0
I just would like to convert them into sup, nothing else.
They are not empty.
I converted one of the files. Does this work for you? -
I know they are not really empty, but they look like empty in Subtitle Edit,
Yes, thx, that sup you did, it works, how did you convert it? (that sup u did is the MovieA part only)
I usually do that with "SE-Convert to sup"-zoom150% -1080p, but with these 2 idx/sub it does not work,
SE does not see the images and my sup is really empty.
So please tell me how you did convert it/them, so I can do the same changing the zoom fitting my preferences.
PS: sub5 and sub6 are basically the same but the 6 is more stretched horizontally.Last edited by maudit; 8th Jan 2023 at 09:20.
Note that the first image really is empty... SE has some trouble with this vobsub as SE assumed the first color was transparent
Should be fixed in latest beta: https://github.com/SubtitleEdit/subtitleedit/releases/download/3.6.10/SubtitleEditBeta.zip -
Weird problem with sound in PotPlayer
By Dreamer in forum Software PlayingReplies: 7Last Post: 22nd Jan 2023, 04:50 -
Subs Overlap Problem
By Seeker47 in forum SubtitleReplies: 6Last Post: 21st Sep 2021, 03:33 -
Weird problem with DVD Decrypter
By ampersand in forum DVD RippingReplies: 2Last Post: 25th Dec 2020, 16:35 -
Convert 29.97fps subs to 23.976fps subs in MKV file?
By zapp7 in forum SubtitleReplies: 3Last Post: 18th Jun 2020, 09:03 -
Weird problem converting / extracting Marvel's The Avengers Blu-Ray
By EmmB in forum Video ConversionReplies: 0Last Post: 8th Jun 2019, 21:31
