  1. Hello!
    I read about keys but I am bit confused.
    I had success in downloading the video I wanted with this command:
    ./yt-dlp -f r1 --allow-unplayable-formats https://voddashhttps.cb.ticdn.it/videoteca2/V3/SingleTitle/2020/04/60022811/CENC/20183050/220329105557/20183050_TIM_FULL_ST.mpd
    The video is encrypted. I downloaded mp4decypt but I am not good to retrieve the keys. I am not good at scripts, I'm a Windows user
    I downloaded a kind of 'keys database' and I thought this was the key
    [{"key": "edef8ba979d64acea3c827dcd51d21ed:b2c70d847ab42bf8f46a6c9be2d37dce"}]
    But obviously it was not or I am not good in using it.
    Could you please help me to understand how to get the keys. The website is TIMVision.it
    Thank you very much
  2. no key on database from your mpd/pssh
    i don't know which database you're referring to but still no match
  3. Originally Posted by lomero View Post
    I answered at your PM. Thx
  4. Originally Posted by Braciata View Post
    1) --allow-unplayable-formats is now --allow-u only
    2) r1 is the best format available. yt-dlp download already at best res available, so -f r1 no need
    3) better to put mpd link into double quote
    4) you're right, wrong key
    so, run only:
    yt-dlp --allow-u "https://mpd"
  5. about your video on first post: here an alternative. 1920x820
    download easy, no drm
    https://hfs265.serversicuro.cc/hls/dnzpfy2w3tg4a3gyvdeh52zwsrid6ebpgk4p33fsdgzrlogteewggwc5nnja/index-v1-a1.m3u8
  6. here 2 keys get from L3. so not work for high res 1080 but only for 720p or lower
    3df2bacb71f94e66aa1820f25357e187:5c71f408ab64cee49fdfbd113d3db188
    3f0bfa589e2245cc8134b77ac55cdc03:5037ab36601e2aef1105c6c8da5f3af6
    anyway decrypt not work with mp4decrypt, need shaka for decrypt this video
    so, because the keys best high res isn't available and shaka isn't easy to use for you, i suggest to download from m3u8 link post above
    (look my post#5)
