what is bitrate and does this effect quality and also what is quantize matrix and what setting is good quality, and finally what is gop structure
Bitrate is like sugar in your coffee. More sugar ->sweeter coffee. More Bitrate -> more information to reproduce the picture -> better picture.
Bitrate can be constant(CB) -> allways the same amouth of picture information or VBR - variable -> it determines how much information you need to reproduce the quality you wanna have. The info curve is moving up and down between the min and max value. It is to put more movie on the final media . it doesn't make better picture.
Quantize matrix -> encoding algorith?? - Just a few of uss know how to use it -> use mpeg standard otherwise you have to be an engineer, I'm not.
GOP -> group of pictures. There is some standard to fallow. I'm using PAL it is max 15 pictures in a GOP structure. IBBP.........etc. A 1 GOP is the smalest element you can cut out from a videostream if you gonna edit or set up chapters. Shapter point can be defined only to the beginning (I-frame) og a GOP. -
Now if veryone gave exaples like this more people around here might understand things better.
Great job JestoriusWe were all NEWBIES once and the only stupid question is the one that's not asked?
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
