  1. Hi everyone,
    I've seen a lot of Python scripts that extracts PSSH from initialization files. But sometimes you just dont want to leave your browser, so I built a website where you can drag&drop your initialization file and it will extract the PSSH information. Everything is done in your browser, there's no interaction with a server. Also, it's open source.
    The website is for educational purposes only and doesn't guarentee anything. Check the FAQ on the website for more information.
    You can see the website URL in the Github link below, don't forget to star the repo while you're there
    https://github.com/efkann/pssh-extractor
    I'm open to any suggestions, questions. I'd really appreciate if you would go try the website and leave a feedback here.
    [Attachment 68561 - Click to enlarge]
    Jan 2023
    Belgium
    i would really appreciate it if you told me what an initialization file is and how to get it lol.
    is it the .mpd file ?
    Edit: nvm , got it
  3. Originally Posted by sparkcakes View Post
    Edit: nvm , got it
    Glad you figured it out, if you tested the website I'd appreciate your feedback
