I have some old videos which I need to do some rudimentary editing on - chop off a few seconds from the start and end, maybe remove some bits during the runtime (it varies).
They are in MKV format on my desktop PC (running Windows 10).
Is there a really easy to use editor which will achieve this with the minimum of fuss?
Results 1 to 11 of 11
None easier then the movie maker that came with Win 10 for 'rudimentary' editing. It can handle MKV files.
Extraordinary claims require extraordinary evidence -Carl Sagan -
I like ShotCut. Very powerful video editor, but also fairly easy to use for what you want to do.
https://shotcut.org/
Simple .ts file editor for basic use?
By CompVid in forum EditingReplies: 23Last Post: 16th Jun 2024, 03:26 -
Simple to use MP4 Video Editor
By mjgreer in forum Newbie / General discussionsReplies: 16Last Post: 2nd Jul 2023, 10:30 -
Looking for an easy to use, basic video editor
By Lake in forum Newbie / General discussionsReplies: 3Last Post: 7th Aug 2022, 21:18 -
Simple Windows Video Editor That Allows Multiple Sounds Overlayed
By pone44 in forum EditingReplies: 6Last Post: 10th May 2020, 14:35 -
Need a simple video editor/encoder software
By meis in forum Newbie / General discussionsReplies: 1Last Post: 4th Mar 2018, 21:45
