I meant to screengrab the error window and thought I had before closing it but apparently I didn’t. Trying to capture a full 6hr vhs tape and I keep getting an error something to the extent of indexing or something. It only happens on long captures. I’ll try to get a screengrab or more specific info but hoping it’s something easy to fix.
Superindex entry limit? But the default settings are supposed to be enough. Are you capturing uncompressed 10-bit or something instead of lossless?
https://forum.doom9.org/showthread.php?p=1583808#post1583808My YouTube channel with little clips: vhs-decode, comparing TBC, etc. -
Thanks for the reply Brad! I believe that was it yeah, but I think my files were still having issues at like 200GB or so. I’ll have to check when I’m home and see what it’s set at and report back!
So I changed it from the default up to 600 after another said it needed like 575 and it seemed to do the trick. I guess my only question is whether there is any downside to doing this? I’ve done it three times now and every time when I come back to the computer it goes to the windows blue screen of death and restarts, but after restarting the video file is fine
The downsides are noted in my link, i.e. some additional overhead and reduced compatibility.
Distorted capture video input in VirtualDub2, OBS works fine
By NotLikeThis8 in forum Newbie / General discussionsReplies: 12Last Post: 24th Mar 2022, 06:34 -
Does Saving a VHS-to-VirtualDub2 Capture as MP4 RE-encode The File?
By Avagadro1 in forum Capturing and VCRReplies: 24Last Post: 9th Feb 2021, 14:15 -
VHS Capture w/ VirtualDub2
By Madz in forum Capturing and VCRReplies: 8Last Post: 23rd Dec 2020, 20:47 -
Virtualdub2 error message
By Chauceratemyhamster in forum Video ConversionReplies: 2Last Post: 11th Jul 2020, 12:59 -
VirtualDub2 unable to capture from AverMedia C039
By Katherine1 in forum Capturing and VCRReplies: 10Last Post: 1st Jul 2020, 20:04
