Hello all.
I have started converting some VHS tapes digitally and have recently started having an audio issue with tapes. I'm not sure how to explain it, but I am getting a garbled sound on audio that is more noticeable on music and high pitched sounds. I have another VHS and I am not having the same issues with the audio, but that particular unit does not display the video as well.
I have ran a tape cleaner through it, but it didn't help. That said, I'm not sure how old the cleaner is and how many times it has been used. I have ordered another, but I figured I would ask on here at the same time to get some input on what you all think it might be, and what I can do or check to maybe get it resolved.
I have uploaded a small clip where you can hear what I am describing. If for some reason you can't access it, I also uploaded it to YT.
https://youtu.be/orG3ZTk9jDM
Thanks all! Much appreciated.
Sounds like this is linear audio (not HiFi), and it seems muffled, so I would start by manually cleaning the linear audio head first.
Cleaning the linear audio head is pretty easy. You can use a Q-Tip for this one and alcohol. -
That was exactly it. I took the unit apart and cleaned the linear audio head like you suggested. Working perfectly now.
Thanks for the info!
VCR plays vhs tapes fine, but vhs-c tapes in an adapter stop after 2-3 sec.
By bobbooptop in forum Newbie / General discussionsReplies: 2Last Post: 19th Dec 2022, 03:50 -
Weird time skip issue during capturing vhs tapes
By Fixir in forum Newbie / General discussionsReplies: 0Last Post: 16th Oct 2022, 05:44 -
HiFi Audio from old VHS tapes
By AstrAir in forum AudioReplies: 26Last Post: 18th Sep 2021, 06:37 -
Problem capturing audio with some Hi-Fi vhs tapes
By Altruo in forum AudioReplies: 5Last Post: 23rd Apr 2021, 19:05 -
Tracking Noise in Audio Track on VHS Tapes
By jbandes in forum AudioReplies: 41Last Post: 7th Aug 2020, 12:53
