Results 1 to 20 of 20
  1. Hello,
    I'm sure it has been asked multiple times, but I can't get any solution to work.
    I'm trying to download DRM videos on RTBF Auvio (example: https://auvio.rtbf.be/emission/kid-paddle-21077)
    I'd want help on how to, since there is a lot that I want to download.
    Can we still get DRM keys nowadays ?
    Thank you
  2. To be more specific, there is 40+ videos (and more coming) so it'd be easier if I can download myself
  3. Banned
    Apr 2022
    Hong Kong
    Yes you can.
    According to my discovery, the website you mentioned uses standard Widevine
    All you need is to put ①PSSH ②License into getwvkeys, and the key will come out.
    Just by reading and hanging around in this forum, you'll find what you need.
  4. Banned
    Apr 2022
    Hong Kong
    Details and steps sent by PM.
  5. Originally Posted by CrymanChen View Post
    Wow !
    I managed to get my account verified on getwvkeys and it works, I managed to download and decrypt needed video+audio and merge !
    Thank you SO much for your time !
  6. Banned
    Apr 2022
    Hong Kong
    Wow !
    No worries, please enjoy it.
  7. Originally Posted by CrymanChen View Post
    Hello
    I have also looked a lot for a solution to this because for a long time I have never managed to download from Auvio again.
    Could you also explain to me how to do it please ?
    A huge thank you in advance !!!
  8. Originally Posted by CrymanChen View Post
    Wow !
    Hello,
    I haven't decrypted content using this method yet, I am still using getwvkeys website,
    but I can't find how to how the client_id and private key files, I suppose I should query the license server with these infos somehow ?
    I'd prefer not to rely on getwvkeys just in case.
    Thank you!
  9. Banned
    Apr 2022
    Hong Kong
    Learn from the forum, TheRedBee.
    You'll get everything it needs to get the keys.
  10. I just wanted to thank you all for the help.
    I gave up but bite the bullet back recently and now I am able to backup and decrypt content independently.
    For the record I am using WKS-Key from CDM-tools (web archive direct link to the tool because it seems offline: https://web.archive.org/web/20230111100753/https://cdm-project.com/CDM-Tools/WKS-Keys/...chive/main.zip).
    Thanks again !
  11. Originally Posted by CrymanChen View Post
    Hello CryManChen,
    newbie also here, would you mind sending those steps via PM as well?
    Would be a great help , parallel to start scrawling through the forum…
    Thx a lot =)
  12. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Hello CryManChen,
    Thx a lot =)
    https://files.videohelp.com/u/303646/Auvio.zip
    Finding the PSSH and License URL is widely covered on this forum, you should be able to get that really quick
    PSSH can be easily found using EME Logger in Tampermonkey
    License URL is
    https://rbm-rtbf.live.ott.irdeto.com/licenseServer/widevine/v1/rbm-rtbf/license
    but it needs the added padding as well. Just look for the url that starts with this
  13. Thank you Karoolus.
    After searching around i have read that in the following thread:
    https://forum.videohelp.com/threads/408635-DL-Auvio-replay-videos-from-belgian-TV-RTBF#post2700970
    you wrote that the .zip file
    contains [...] a working CDM.
    How to understand this exactly, does the script contains hard coded device_client_id_blob + device_private_key (means ready to send a licence request), or do I still have to bring my own CDM keys?
  14. It has a valid working CDM inside, seemingly extracted from a Xiaomi Redmi 5 Plus. You don't need your own CDM.
  15. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Ah crap, I thought it was an Android Studio CDM. Oh well, plenty of L3's to go around I guess
  16. Using the pywidevine version with the protobuf update from @A_n_g_e_l_a, here a script to examine the client-id blob:
    import sys
    from google.protobuf import text_format
    from pywidevine.L3.cdm.formats import wv_proto4_pb2 as wv_proto4
    client_id = wv_proto4.ClientIdentification()
    file = 'pywidevine/L3/cdm/devices/android_generic/device_client_id_blob'
    if len(sys.argv) > 1:
        file = sys.argv[1]
    with open(file, 'rb') as f:
        try:
            client_id.ParseFromString(f.read())
            print(text_format.MessageToString(client_id))
        except:
            print('client id failed to parse as protobuf')
  17. @Obo
    i have error when run your script
    ImportError: cannot import name 'wv_proto4_pb2' from 'pywidevine.L3.cdm.formats' (D:\WKS-KEYS\pywidevine\L3\cdm\formats\__init__.py)
  18. That's why I mentioned the protobuf update...
    Change the lines containing wv_proto4 and replace every occurance of proto4 with proto2. That's line 3 (2 occurances) and line 5.
  19. thanks for your explanation. all right
    but still: we can check, trough this script, if cdm is valid or revoked? or you can check validity only with a test to some site?
  20. You can only check if your CDM is locally valid. It's just a script to parse the client blob file and output its content.
